lock up tranny
Old Jan 24, 2009 | 07:57 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
lock up tranny
im going from tbi to carbed and do i need to lock my tranny up so it doesnt burn up or how should i do this. i was told i could put a switch in there but it would be a hassle to keep flipping the switch.
Old Jan 24, 2009 | 08:11 PM
ls six's Avatar
Re: lock up tranny
More information please. What are you starting with? If your not using the feed back system used on OE carbed cars then ypu will need to control the TCC some how if you want the benifit of better milage.
If you leave it unlocked you proabably wont over heat the trans since it wont lock up a WOT anyway or under high load. But if you install a high stall converter it's possible to generate enough heat to dammage the trans though it's unlikely.
Just wire up the swotch and dont wory about using it unless your cruising long distance. Milage around town will suffer a little but not much.
Old Jan 24, 2009 | 08:22 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
ok cool its a 700r4 but should i flip the switch when i take it to the track though right or does it not matter.im going from a 305tbi to a 350carb but i will be using the feed back or drop down cable to the tranny to the carb. also im not installing a stall converter neither yet that like the last thing i do lol for now after this motor is is.
Old Jan 24, 2009 | 09:13 PM
ls six's Avatar
Re: lock up tranny
You only use lockup during cruise / low load situations. If you leave it on any other time when you are accelerating or stopped you will burn up the TC clutch in a matter of minutes.
The TCC locks the converter together in a solid piece using an internal clutch. And just like a clutch on a manual trans it needs to be reloesed when you stop, but since it's a very thin clutch and has little surface area having it on and exposing it to load will cause it to slip and burn up.
The cable you reffer to is the TV cable and is different than a kick down cable. A kick down cable simply forces the trans to drop from 3rd to 2nd when you accelerate hard in older 3 speed cars.
A TV cable regulates the pressure aplied to the clutches depending on throttle position and als affecst shift tomong. Higher throttle angles cause the line pressure to rise for more holding power and firmer later shifts.
Old Jan 24, 2009 | 09:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: lock up tranny
The torque converter heats the fluid up most when it's cruising below stall, not when it's under load.
Old Jan 24, 2009 | 09:26 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
nvm down low
Old Jan 24, 2009 | 09:35 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
i really dont feel like burning a tranny up or if you could explain it a little better idk y im not getting what your saying so what can i do if i dont lock the tranny up and what can i do if i do lock it up?
Old Jan 25, 2009 | 09:31 AM
ls six's Avatar
Re: lock up tranny
Wrong. Under cruising conditions the converter slippage is at a nimimum. Under load it is closer to stall speed.
Old Jan 25, 2009 | 10:01 AM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
so lilke at wot flip the switch up and when i cruise dont flip it up?
Old Jan 25, 2009 | 08:44 PM
ls six's Avatar
Re: lock up tranny
Only ever use lockup during cruise conditions and turn it off if you are about to do accelerate hard or stop.
Old Jan 25, 2009 | 09:06 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
ok cool so when im gonna punch it turn it off and when i stop turn it off and when i just drive normal keep it on. thanks alot for your help ls six i get it now lol
Old Jan 27, 2009 | 07:29 AM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: lock up tranny
Old Mar 26, 2009 | 08:59 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: lock up tranny
okay now how do you wire it up then? moneys extremely tight and i wanna rig it to work on a switch, but where do my wires go? i have a 4 prong connector on my 700r4. can i lock it up by using this or do i absilutely HAVE to drop the pan?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
