RPM's with 3.42 and 3.73 gears
Old May 2, 2001 | 03:41 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I have a 700R4 in a 86 IROC with 2.73 gears right now but when I put my 355 in I want to go with 3.42 or 3.73 gears but don't want the engine to scream. About half of my driving is a 75 mph. I have 245-50/16 tires. What do you guys run for RPM with these gears?
Thanks,
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old May 2, 2001 | 06:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have 3.73s (stock with the L69 option); my car's RPM is about 2900 at 75 in 5th. It would be slightly lower with a 700 in OD and lockup, maybe 2700-2750.
ICON Motorsports
Old May 2, 2001 | 08:24 PM
82camaro's Avatar
Car: 82 camaro SC
3.73's with overdrive 2150 at 60mph.
2550 at 75mph.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited May 02, 2001).]
Old May 2, 2001 | 09:17 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
3.73 at 70mph with 245/50r16 for me is almost exactly 2500 rpm in OD- slightly less with my new 255/50 tires. this is a 700r4 in lockup. If i could do it again i would have gone with 3.42 because it is a better all around gear, especially for a tpi car. If you are keeping the tpi i think the car would be faster with a higher gear and you'll get better milage.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
[This message has been edited by '87FAKE-IROC-Z (edited May 02, 2001).]
Old May 3, 2001 | 12:44 AM
Bort62's Avatar
Figure out what MPH you should be Running in the 1/4, at the end Via HP estimates...
Then Figure out what gear would give you that MPH at your power peak, at the trap...
That Should Give you a pretty decent stab at the best performance gear, Now that has nothing to Do with Highway.
I plan On installing 3.42 On mine, Good all around gear.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 3, 2001 | 07:57 AM
purpleworm's Avatar
I have 3.42 and 65 mph I am about 2100 RPM's. I get about 25mpg when i run about 85-85MPH. Huge performance gain and i find the car drives much better.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old May 3, 2001 | 12:26 PM
Car: 1986 IROC
Thanks for all of your inputs. I think I am leaning more towards 3.42 gears since I do time on the highway. I guess that would still be a great gain over my 2.73 gears!
Old May 3, 2001 | 06:32 PM
82camaro's Avatar
Car: 82 camaro SC
huge improvement.
10.47:1 overall first gear ratio with 3.42's
8.35:1 overall first gear ratio with 2.73's
Around here the speed limit is 55-60 on the highways, so 3.73's/locker work great for me. If you don't have posi, a powertrax locker would be a good addition. Deeper gears can result in traction problems.
82camaro
Old May 3, 2001 | 07:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I like my 3.73 gears way better than the pos 3.23 gears that every one likes. I get better traction with my 3.73 gears and as far as my 5th gear vs. 4th in my old 700r4 do the math because the t-5 has a much taller over drive.
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Regal105
Aug 23, 2015 03:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
