T-56 Swap problem
Old Apr 18, 2001 | 04:50 AM
JIMS406RS's Avatar
T-56 Swap problem
I Have a T-56 in my 91 Rs. I used the Dakota Digital speedo interface to calibrate my stock electric speedo but it gets bad interference when sitting still. the interference increases if I rev the motor when sitting still. Does anyone else have this problem or any suggestions?
91 RS
HOTCHKISS LCA'S PANHARD AND SPRINGS.
ALL URETHANE BUSHED
SUSPENSION TECHNIQUES SWAYBARS
SUBFRAME CONNECTORS
SPOHN TORQUE ARM
KYB'S
WHITE FACE GAUGES
COWL HOOD
92 Z28 SPOILER, GRILL AND FOG LAMPS
ADMIRAL BLUE
T-56
3.73'S L/S
SPOHN LCA BRACKETS
406 DFI
SUPER RAM
AFR 190
COMP CUSTOM CAM....
Old Apr 18, 2001 | 09:15 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I had this problem with my Cyberdyne box for a while. It hasn't happened in a while though so I'm not sure why it did it. Well come to think of it, when I went on a road trip down to New Orleans I had a freind's small cb radio to communicate back and forth between cars and whenever I would talk on it my speedo jumped around alot. There were other times though before this when it would do the same thing. Not sure why though.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Apr 19, 2001 | 06:33 AM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Call Dakota Digital. They will help you with your problem unlike Cyberdyne.
Old Apr 19, 2001 | 01:23 PM
JIMS406RS's Avatar
I have called dakota digital, all they could tell me is I had some interference from the tach signal. It didnt take a rocket scientist to figure that out. I need to know how to get rid of it.
91 RS
ALL URETHANE BUSHED
SUBFRAME CONNECTORS
SPOHN TORQUE ARM
KYB'S
WHITE FACE GAUGES
COWL HOOD
ADMIRAL BLUE
T-56
3.73'S L/S
SPOHN LCA BRACKETS
406 DFI
SUPER RAM
AFR 190
COMP CUSTOM CAM....
Old Apr 19, 2001 | 02:01 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by JIMS406RS:
</font>
Is your coil noise suppressor hooked up? It is a little can shaped thing that is located on the firewall(well at least in my car) it intercepts the message from the dist before it gets to the gauge. If it is hooked up maybe it is bad or something
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 23, 2001 | 07:07 PM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
</font>
well I have no clue about speedos but my idea is to hook up one of those noies reducers for car radios. that might work thoes are made to take out the interference of the spark to the aftermarket radio so that might be causing the same problem on the speedo.
hope this helps email me if it does
Chuck
I'm not shy, I just
observing my prey.
don't forget the Firebird is an F-Body TOO
Old May 7, 2001 | 01:01 PM
Mark W. Winning's Avatar
Mine worked fine for two days, now it acts like the ones posted above. When we first start the car, its fine. Then, after about 5 seconds it shoots to about 50 mph and will climb if you rev the motor.
Anyone fixed this yet???
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old May 7, 2001 | 03:15 PM
Birmass's Avatar
I've heard something about twisting the input and ground wires around each other helps. I'm not positive though.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
