c4 t56 will it fit camaro
Old Feb 4, 2009 | 11:03 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
will a 6 speed from a 90 corvette fit a camaro i know c5 and c6 dont fit but im having trouble figuring out if the 90 would thanks
Old Feb 5, 2009 | 09:55 AM
godreject's Avatar
Re: c4 t56 will it fit camaro
need help some1 please help, i have the opportunity pick up the full engine and tranny combo from a 90 corvette to swap into my 91 camaro but i need to know if the t56 fits
Old Feb 5, 2009 | 06:40 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Nope. The rear mount is different and there is no provision for a torque arm mount.
Old Feb 5, 2009 | 06:44 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
** as stated above the rear mount is diff. but they sell a special mount for 3rd gens.
not sure about the torque arm tho
well i think most of the 90 vettes came with a tpi and a t56
if you already have a 350 engine, maybe tpi? there is really no huge benefit of the engine part but as far as tranny goes it will bolt up to your block, unless you already have a manual tranny in your car now, you will need the pedals, and shifter hole.
if you are interested in the whole swap, thats cool too, as far as i know you will need a new serpentine belt setup.
what engine do you have in your car now? tranny?
Old Feb 5, 2009 | 09:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
C4 Corvettes came with the german ZF 6-spd, not the T56. The short answer is no - it will not work.
Old Feb 5, 2009 | 10:55 PM
godreject's Avatar
i figured no but was unsure, i currently have a 350 tpi auto, looking to go 6 speed once a deal comes across, although the car is a B4C so im unsure if i really want to hack it up, thanks 4 the response i passed on the deal guy wanted 1000 for the full engine 6 speed tranny combo off a 90 vette with 90 k miles good deal but i have the same engine so only benefit would be the 6 speed if it fit,
Old Nov 29, 2020 | 04:40 PM
Lauper84's Avatar
Car: 1984 Camaro Z-28
Engine: SBC 355 Gen 1
Ok but what if you transferred the whole powertrain over from the c4 to the f body? Would it fit? Would you have to change out the whole rear?
Old Nov 29, 2020 | 04:57 PM
Ever been underneath a C4 and SEEN how it's built? As in, LOOKED AT?
Would it fit?
No.
Besides the monumental engineering headache that doing that represents, it would be only the beginning.
The short answer is NO. The long answer is NO. While there may be people who can make it happen, if you're posting on the Internet and asking this kind of question, the answer is NO.
Old Nov 30, 2020 | 08:12 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Dont hack up your B4C. The automatic in it is a very well made transmission. Just live with it and enjoy it. When you get tired of butchering that car and sell it the next owner will thank you for leaving it intact.
kccisco
Jun 6, 2010 06:42 PM
chaoz28
Nov 25, 2008 02:29 PM
NonczRS
Jan 20, 2004 08:17 AM
David Petersen
Apr 7, 2003 06:25 PM
