ideas for manual tranny----400 plus hp
Old Nov 8, 2009 | 03:34 AM
kccisco's Avatar
Car: 85 transam
Engine: 76 chevy 350 carb
Transmission: t-5 3.23
call me a noob but i know as much abot tranies as i do abot how to do open heart surgery (and thats nothing) but how to strip one and put it bak together and wat i want to know is, is ther a trany i can find that will support over 400hp. iv got a t5 with a 350 pushin around 350hp and im gonna build it more cas i did a noob move and stuk the motor in without cleaning it or replacing any gaskets. i took the tranny in for an overhaul before i had the motor in and one nite i let the motor rip and now the tranny shakes in 3rd gear. im more of a manual tranny guy since the fact of reving the motor and droping it into gear just bothers me no matter how well the trqu converter is. i dont like buying new off the internet and i would like to pull a tranny that could bolt up into my fbody with little to no modifications, im young but call me old school cas i like to learn by doing so pulling a tranny from a wrecked car and overhauling it and watching it grow into something i can be proud to say i built, not i bought.
Old Nov 8, 2009 | 09:49 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: ideas for manual tranny----400 plus hp
Any spirited driving with 400hp should be looking at a LT1 T56 swap. There's a sticky at the top of the forum on the swap, it's not real hard. If you want to keep a T5 clutch/linkage setup, you can put an adaptor plate on a LSx Fbody/GTO T56 and bolt it up.
I have both a LT1 T56 and a GTO T56 ready for rebuild/sale if you're interested in either.
https://www.thirdgen.org/forums/engi...ml#post4333009
Old Nov 8, 2009 | 05:37 PM
kccisco's Avatar
Car: 85 transam
is ther certain restrictions as to wat year the car is or wat make the car was, or is all t56s the same
Old Nov 8, 2009 | 05:53 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
1993 T56's are rated for less power than the rest. 1993-1997 T56's will bolt up to a Gen I block. 1998-2002 T56's will only bolt up to a LSx block unless it has the aforementioned adapter plate. Corvette T56's dont work since they're mounted to the transaxle instead of the engine. Im unsure even if a GTO T56 will work because Id ont know if those use torque arm rear suspensions... I remember them having IRS, so I doubt it. You need a place to mount the torque arm unless you want to mount it to the crossmember.
Internally, most of these are the same, but external differences matter. Try to stick to an F-body T56. If you get a T56 from a GTO, I bet you could find an F-body T-56 tailshaft with the torque arm mount on it and bolt it up, but I cant imagine those are super easy to find.
Old Nov 8, 2009 | 09:08 PM
85MikeTPI's Avatar
I assume you mean "bolt up to a SBC block", but even then both Quicktime and Mcleod sell conversion bellhousings that allow the LSx T56 to mount to a SBC/BBC block. The adapter plate is only needed if retaining the older bellhousing/clutch setup.
GTO is totally different internally. Triple/double cone synchros and MN12 gearing. GTO tailhousing is identical to Fbody, no concerns there.. GTO T56 is externally identical to Fbody T56, only slight change needed to bellhousing/shifter-cup.
Old Nov 10, 2009 | 03:21 PM
Car: 1992 Camaro RS
That's what I meant. I was just trying to say that it takes special parts to mate an LSx T56 to a Gen I block. It seemed a bit expensive and troublesome for me so I just decided to get an LT1 T56 and never looked back, so I wasn't super familiar with what adapter plates and conversion bellhousings were necessary or not. It's just yet another complication. And given the trouble people seem to have with LS1 T56 hydraulics, I'm not sure I'd want one.
That's very interesting. Good to know. So is the GTO trans stronger than the F-body trans?
Old Nov 10, 2009 | 03:34 PM
85MikeTPI's Avatar
The bellhousing issue was always tough for LT1 T56s since there was no SFI solution until McLeod just released theirs this past year. The older T5/muncie/saginaw type SFI bellhousings were available, so the adaptor plate was a pathway to using them. Still, if you have access to a LSx T56 and going SFI, the cost will be less than converting the trans and getting an LT1 SFI.. I still wouldn't use an OEM hyd slave/TOB like you say..
The trans is warranty rated the same as the fbody (450lb-ft), but the lower gearing allows them to be used in heavier vehicles or not-quite-as-powerful motors. The new synchro designs make for VERY smooth shifting. I wouldn't say they are stronger, but a much more modern design as used in the CTSv and Corvettes.
mike
Old Nov 14, 2009 | 10:21 PM
kccisco's Avatar
Car: 85 transam
sry iv been out of town all week workin, but wat im getin at is the t5 belhousing would make it work and the t56 shold bolt up into my car with minor modifications. well i live in a small town (im talkin 16,000 people) and so iv called all over the state and no t56 has ever been seen in the any of the junkyards, so now im in a semi desperate need of a t56 but i dont hav pay pal, if any1 has a t56 for sale for 1000$ or less in need of an overhaul or not, send me an email and i can either sign up for pay pal or find a way of paying for it
Old Nov 14, 2009 | 10:42 PM
85MikeTPI's Avatar
Where are you located? (Might want to fill in your profile)
As I mentioned, I have a GTO T56 that I've already dismantled and have the replacement parts for it to get back to 100% operational. Shoot me a PM if interested and maybe we can work something out.
The T5 bellhousing adaptor plate is here:
http://www.thegearbox.org/catalog/it...17/4803441.htm
mike
Old Nov 15, 2009 | 02:37 AM
kccisco's Avatar
Car: 85 transam
well im located in the dickinson nd, trust me its the boon docks but its one of the only cities wer u can walk into a place and get hired on the spot without an application and get paid more than if u had a college degree.
how much r u asking for that gto t56?
Old Nov 15, 2009 | 12:59 PM
85MikeTPI's Avatar
PM sent
Old Nov 16, 2009 | 08:39 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
what all would be needed to make a GTO t56 work?
if i got a relocated torque arm bracket, would everything else be able to bolt up?
just curious because torque rating is not a concern to me as much as reliability and smoothness
Old Nov 17, 2009 | 09:22 AM
85MikeTPI's Avatar
For which motor/clutch/bellhousing setup?
The GTO T56 is exactly the same externally as the LS1 T56, just has upgraded internals. For a Muncie/T5/Saginaw clutch/bell, you need to add an adapter plate (http://www.thegearbox.org/catalog/it...17/4803441.htm) shorten driveshaft, and make/buy an "aftermarket" T56 Xmem from Spohn.
For a LS1-type bell/clutch setup, you can get a SFI conversion bellhousing from quicktime or McLeod and run the LS1 OEM hydraulics and a standard push-style clutch.
For a LS1 motor swap, it's a direct drop in...
Old Nov 17, 2009 | 10:49 AM
chevysaregr8's Avatar
Car: '85 Camaro Z28
Engine: 383, 507 horsepower
Transmission: Borg Warner Super T10
Axle/Gears: Aftermarket 9in. 4.30, full spool
Nothing is cheap on these cars. But they do hook up rather well. Jegs has torque arms for sale that mount with a saddle in the tunnel. I recommend the adjustable one for 50 dollars more. They are something you'll always be able to have in your set up. Making your stock one work is a temp. fix that you may not use in future swaps. I priced everything out and the Jegs arms are a great deal. At least give it a look. Thats what I used.
Old Nov 17, 2009 | 11:31 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
oh, so it would be more difficult than a lt1 style if i was bolting to a gen1 sbc... gotcha
Old May 22, 2010 | 04:25 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
do they salt the roads there?
Old May 24, 2010 | 08:47 PM
kccisco's Avatar
Car: 85 transam
yep they salt the roads
Old May 24, 2010 | 11:01 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You ever swap in a t-56? I got a retrofit unit from 85miketpi, with upgraded internals to handle 700 ft lbs of torque. Its a pretty easy swap if you get the retrofit stuff and keep the stock bell and hydrualics. I spent the extra $ and got a xmember from Spohn which moved the TA mount to the xmember. I also got the adjustable TA from them too.
Old May 25, 2010 | 08:40 PM
kccisco's Avatar
Car: 85 transam
well i kinda sorta built my own xmember with a welder, alot of blood and cussing but wen i got done it actualy looks perfesional considering this was my only t56 swap, i got the adapter plate off of thegearbox so i kept the old belhousing since i felt the hydraulic clutch surficed and didnt feel like messing with it since i have a severe hatred of working under my car. all i got left is test driving, finish trying to piece the interior bak together, and figuring out how to get my spedometer work.
Old May 25, 2010 | 09:32 PM
travis401's Avatar
Car: 91 Camaro RS
Is it a cable or electronic speedo?
Old May 27, 2010 | 12:32 AM
kccisco's Avatar
Car: 85 transam
its a cable so basicaly wat i need is a conversion from electronic to mechaninc spedo
Old May 27, 2010 | 12:41 AM
travis401's Avatar
Car: 91 Camaro RS
You can swap out to a stock electric speedo, its been done but Ive heard is a pain. You can get a converter box here, but its $325. You can also have the tailshaft machined for a cable speedo gear but that is also $300+.
Old May 27, 2010 | 01:06 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Did you have to cut the transmission tunnel to make the shifter fit for your swap? That's the main reason I haven't gone with a T56 yet.
Old May 27, 2010 | 02:08 PM
travis401's Avatar
Car: 91 Camaro RS
The T-56 shifter sits about 2 in further back in the tunnel, so yes you have to cut the hole bigger. All the retro fit is, is an adapter plate that bolts to the bell to allow the trans to bolt up. Its about a 1/4 -1/2 in plate.
Old May 27, 2010 | 09:00 PM
87WS6's Avatar
According to the link for the adapter plate, it allows the transmission to be mounted at an angle which is required for the T56 to be oriented the way the T5 was. The T5 wouldn't clear the hole for the shifter either if you mounted it straight. From the factory they are rotated slightly which ***** the shifter assembly so that it fits through the hole. The difference in orientation could make up for that 2" of clearance that is needed. The description for the adapter plate also states that you can install it straight if you wish. I wonder if people who are cutting the transmission tunnel are installing it straight instead of cocked. Then again I suspect that most people don't use the adapter plate which changes things.
Old May 27, 2010 | 10:07 PM
travis401's Avatar
Car: 91 Camaro RS
If you use a premade xmember (like the spohn one I have) instead of making your own, you cant install it straight up. If you make your own xmember you can though. The plate is drilled for both options though.
Edit: I ment, you have to install it straight up, if you try cocked like the t-5, it wont line up with the xmember bolt holes.
Old May 27, 2010 | 11:11 PM
87WS6's Avatar
That's the key then. I'll fab up my own crossmember before I cut my transmission tunnel. If I can tilt the transmission and use this adapter to do that, then that's my best option. It looks like I'm going to be going with a retrofit T56.
Old May 27, 2010 | 11:18 PM
travis401's Avatar
Car: 91 Camaro RS
Either way, youll have to cut the enlarge the shifter hole.
Old May 27, 2010 | 11:24 PM
87WS6's Avatar
I thought I wouldn't have to if I used a custom crossmember?
travis401's Avatar
Car: 91 Camaro RS
Upon further thinking, I dont think you can install the t56 at the cocked angle like the t-5. I think the other pattern in the adapter plate is for different style straight up bolt pattern bell housing. If you try and **** the trans, the shifter will point off in what ever direction you **** it. And with the adapter plate youll need either an LS1 t-56, or swap the main shaft for an LS1 main shaft. The other shafts are too short and wont work. Youll also need an extended pilot bushing (also sold on thegearbox.com).
Old May 27, 2010 | 11:26 PM
travis401's Avatar
Car: 91 Camaro RS
Sorry for the misinformation, I was trying to do 4 other things and respond on here.
Old May 27, 2010 | 11:33 PM
87WS6's Avatar
Well the description of the adapter plate clearly states that it needs to be rotated on the adapter plate for F-body applications. Seems reasonable to me since that's what they had to do with the factory T5. Then again that may just be for compatibility's sake on the T5 bell housing. You still may have to trim the tunnel some to pull it off.
I have an aversion to cutting my car's body. Sure it will make something work now but how will I feel about what I've done in 10 years or more? How will this effect future swaps? Technology will improve. It stands to reason we'll be doing swaps beyond LSx and T56's in the future.
Old May 27, 2010 | 11:46 PM
travis401's Avatar
Car: 91 Camaro RS
With 6 gears, in 10 years youll probably be wondering why you didnt do it sooner. Honestly even if you wanted to go back to the t-5, a little sheet metal work and its all back the way it was. You can always keep the small piece youd hafta cut out and weld that back on. Its not like you gotta cut apart the whole trans tunnel, you just gotta cut a 2" max long piece out of the back of the shifter hole. I went from t-5 to t-56, got the LS1 gear set, kept my stock hydrualics, and havent even thought about putting something else in there much less going back to the 5 spd. The t-56 drives like it was ment for 3rd gens.
Old May 28, 2010 | 03:59 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
sorry don't mean to hijack the thread but how do you like that setup, already got it all installed? got a similar configuration waiting to go into my formula
good info on the trans options, especially the GTO T56, i wasn't aware of that option.
Old May 28, 2010 | 06:04 AM
85MikeTPI's Avatar
The T56 must be mounted straight up. The adapter plate has 2 sets of bellhousing bolt patterns to make it work with all different kinds of retrofit applications. The F-body T5 was rotated, so there's a pattern to accommodate the T5 bell angle and keep the T56 straight up. The older saginaw and muncie 4-speed (and SFI) bellhousings were straight up, so there's a bolt pattern to accommodate them and keep the T56 straight up.
Old May 28, 2010 | 09:17 AM
87WS6's Avatar
No doubt the T56 is a better transmission. I've got one in my GTO and my Firehawk had one. (The GTO's does shift a lot smoother.)
Old May 28, 2010 | 11:52 AM
travis401's Avatar
Car: 91 Camaro RS
Ive had the trans in for about a year now and love it. The spohn xmember and torque arm was a bit pricey but well worth it. I made a road trip from WA state to Texas in JAN. The 6 gears instead of 5 on the long stretches of open highway were nice.
Old May 28, 2010 | 12:04 PM
87WS6's Avatar
I've driven my GTO long distances and never found the 6 gear to be worth while outside of cruising to save gas. I hate it when other cars are around because the car has no acceleration in 6th until you are well over 100MPH. (Or so I'm told.)
Old May 28, 2010 | 01:28 PM
85MikeTPI's Avatar
5th and 6th are both overdrive gears and are not for acceleration. They allow you to gear down the rear-end for optimal performance, while still cruising around and not using gallons-per-mile..
As for being "able" to accelerate in 6th, it's all relative. Your GTO has a "slightly" better 0.56 6th gear, but my 427 motor can still accelerate it's 0.50 6th gear at 60mph...
Old May 28, 2010 | 01:34 PM
travis401's Avatar
Car: 91 Camaro RS
If Im in 6th at 60mph and need to pass or something, Im just gonna down shift. Why would you try and do something like that in 6th?
Old May 28, 2010 | 02:14 PM
87WS6's Avatar
Like I said the car is simply not very responsive in that gear. I didn't say I wouldn't downshift to pass. I certainly do and have done it plenty of times. Unfortunately once in front of a highway patrol officer in a no passing zone.
Old Jun 6, 2010 | 06:42 PM
  #42
kccisco's Avatar
Car: 85 transam
ok i finaly got my shifter in but i will be the first to tell you it does not look pretty, but i do notice a small leak at the rear of the transmission but heres the thing the shifter is not leaking and its not leaking out of the driveshaft but yet i still can find the leak to save my life
camaro11j
Sep 19, 2018 08:49 AM
Toolsin
Feb 2, 2016 06:55 AM
formula1lle
Jan 29, 2016 10:56 AM
fasteddi
Sep 2, 2015 10:29 AM
dhonda200
Aug 11, 2015 11:50 PM
