Real main seal leaking ->new clutch plate?
Car: GTA '88
Engine: 420 Dart SHP
Me rear main seal has been leaking slightly about 1-2 months. I'm going to replace it next week.
The question: is my clutch plate a goner? I sure would not like to buy a new one just because of that! Is it enough if I just clean the plate with a clutch/brake cleaner?
The clutch is slipping occasionally for now.
-88 GTA 305TPI/T5, 9-bolt 3.42 posi, Crane cams 2032, Edelbrock TES #6872 black satin coated, Dynomax 3" cat-back, ported+portmatched heads, base, plenum, Accel runners, multiangle valve job, no cat, no air, Haltech E6GM ECM, MSD6AL, MSD blaster II-coil, Accel 300+ wires 8mm. http://www.helsinki.fi/~kjilehto
Car: 4
Engine: 6
Transmission: 5
A "slight" rear main leak will not get on the clutch, because the leak is on the opposite side of the flywheel. So I doubt that the clutch will un-wear itself out.
I'd say that if you're going to all the trouble of tearing the car down that far, and the clutch is hosed, there's not a lot of sense in putting it back together with the old one, which means you'll just have to tear all that stuff down again in a few months to replace it. Go ahead and do it now and get it over with all at once.
ICON Motorsports
ICON Motorsports
1992 Trans Am
May 10, 2023 07:19 PM
