Reverse input clutch wear...(how mush is too much)
Old Mar 24, 2001 | 03:33 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
OK, while inspecting the parts coming out of the tranny befor a rebuild i didn't notice anything bad.
After cleaning, the only part i'm concerned with is the splines for the reverse input clutch (outer)
It looks like the belleville plate slammed a notch into the splines. Not everywhere though, it seems wear is unequal though the circle, maybe 33% on thrust, 33% on coast, and the rest looks like the steel rammed into the spline (not tooth wear but the actual face of the spline)
I took the drum to work and resurfaced the outside (for flatness) and never even looked into it until today. The top ridge of the piston sealing area looks like ocean waves (the seal wear pattern (more like a mark) is 1/2 way down from there, so seal leakage isn't a concern))
Should I change it? If so (I hope the answer is yes, because i don't like the way it looks... rest of parts looks a o.k.) is there a better part to replace it with? The stamped steel inner part looks changable, but not really. Can I weld cold rolled steel keyway in there (to match the steel splines)? The whole gm setup here looks real cheap and thats not as cheap as I am (if I can make it better) but I don't want to skimp on something that may break 1/2 way through its useful life.
By the way, I can see steels impacts up to the 5th steel.
If I have to stick with a gm piece, does anyone have the part number?
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 25, 2001 | 07:48 PM
JoelOl75's Avatar
BTT
Old Mar 25, 2001 | 08:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Swap it for another stock piece, and replace the Bellville spring, and all other steels that splined to the RIH, and stop "gunning" it in Reverse!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old May 21, 2001 | 11:49 PM
racerRoy's Avatar
Replace this drum with a better used or new. dont get one from gm .try a tranny shop or a good used. if your in a bind i can get one for u 65 + shipping. new
Old May 22, 2001 | 07:04 AM
JoelOl75's Avatar
Wow you dug this one out of the archives! I already finished the tranny about a month ago. I got a new one from gmpartsdirect.com and it costed $45.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
mfp189
Sep 27, 2015 09:25 AM
