Corvette Servo
Old May 24, 2001 | 01:04 AM
XLcIROCZ's Avatar
Corvette Servo
I've been hearing about putting a Corvette servo in the Camaro's 700r4, what is that all about?
Old May 24, 2001 | 01:10 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
http://sethirdgen.org/servo.htm
check that site out.
its a piston, its smaller than the camaro one, and applys the shift faster
Old May 24, 2001 | 10:43 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
The vette servo, is good for a couple of reasons: 1) As was said in the last post, it will give you a firmer, quicker shift, because it takes less fluid pressure to engage the servo which allows the band to "catch" the input drum and 2) it will prolong the life the band, (under normal driving conditions, ha....ha..!!).
Another thing I would suggest is to put stiffer springs in the 1-2 and 3-4 accumulator housings, this to will give you firm, solid shifts, which will increase the life of your tranny as well (Have this done when you get your tranny rebuilt). You could even use a short piece of metal tubing instead of springs to prevent the accumulator pistons from moving.
1987 383 cu.in. IROC-Z: TPIS MiniRamIII / GM FastBurn heads/ 10.6:1 compression
Comp cams custom grind: Dur'n 224/236 Lift .536/.555
Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter
MSD Billet Distributor, Dig 6+, & Blaster coil
Hooker Supercomp Long tube headers
Old May 24, 2001 | 12:47 PM
82camaro's Avatar
Car: 82 camaro SC
The servo and a .5 boost valve make an excellent shift kit.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 25, 2001 | 12:20 AM
transfixleo's Avatar
Relax, if you have an IROC, then you should already have a Vette servo.
Old May 25, 2001 | 02:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure? What year IROCs had the Corvette servo?
Old May 25, 2001 | 09:34 PM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by transfixleo:
Relax, if you have an IROC, then you should already have a Vette servo.</font>
Mine did originally. The 1-2 accumulator and spring wasn't the same as the Vette part #'s though.
I went with a hi-stall converter like the way it performs since the overhaul.
Heres the GM part #s for you guys that may need them....
8634940 valve
8647351 seal
8639164 spring
8673039 housing
8642079 piston
Have fun
Mike L.
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old May 26, 2001 | 12:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Save yor money. go to http://www.hptransparts.com and get the complete servo kit with accumulator pistons for less than $20
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
