Just curious to know if anyone installed a Super T10,Jerico, or any other 4 speed manual tranny in their 87-92' camaro WITH A TUNED PORT INJECTION, not carberauters(mispelled). If u have please state which tranny u installed and what were the exact parts u needed to do the conversion.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
Man,
You need an Rx for some ritalin or something. I don't have an answer for you, and it's probably not a common enough conversion to be able to get a response...especially within the timeframe that you apparently loose your cool
made you look!
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
made you look!
Clem
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
I dont see why putting a 4-speed manual trans into a TPI is any different than TBI or carb. You get the trans, bellhousing, crossmember and driveshaft, and some way to hook up the clutch.
The 82-83 F-bodies have 4-speed manuals, you should look at one of them.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
yeah i know there shouldnt be any problems, but i would like to know what are the differences that might occur intalling a 4 speed from a five speed, will it affect top speed, will i have to do any modifications to the underbody or anything else.
I am sure the drive shaft will need to be longer.
yes you will not be able to go as fast because of the car reving higher than with the OD.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Pay attention:
The four speed top gear is a 1:1 ratio, and the five speeds fourth gear ratio is the same. The fifth gear,(the overdrive) is .76 or whatever. So you would need to compensate with the rear gears. With the overdrive, the engine would work harder. You would need some serious horspower to push the overdrive to the rpm limit of the engine.
By the way, I was going to do the same, and dump the stock 200r, and back my 350 with a super T-10, so I bought one, then found out that it would be alot easier, and cheaper to drop a T-5 in. Basically, the clutch linkage was the problem.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
[This message has been edited by stingerssx (edited May 27, 2001).]
