fitting 3.73's
Old May 27, 2001 | 12:54 PM
aerofox_1's Avatar
fitting 3.73's
Here's the deal, I've got a '92 RS that I want to put 3.73's in. The old 2.73's just aren't cutting it. I have a ten bolt rear end and I need to know what size my rear end is. Weather its a 7.5", 8.5", 8.2" or whatever. I also need to know how many splines are on the pinion. Or if somebody could provide me with the part number and brand name that would be great. also the code GHP C 119 1 is on the rear axle.
'92 Camaro RS, purple w/silver racing stripes. 305, open element filter, flowtech headers, Summit Fully Welded Muffler, hypertech thermomaster chip, PROFORM aluminum roller rockers w/1.6 ratio, removed A.I.R. system.
Old May 27, 2001 | 02:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, the GHP is a 2.73:1 rear ratio.
Your 10-bolt is commonly called the 7.5" but it is actually 7-5/8".
Since you have a 2.73 (2 series carrier) you need 3.73s made to fit a 2 series carrier. Summit sells the Richmond gears you need RMG-4900071. These are the ones that I have, and other than being a little noisy, they are pretty decent if you install them correctly and allow them to "break in".
You may want to think about getting a posi or locker or some sort of traction device. Since you have to have the ring and pinion setup, you might as well get a new carrier, and it might as well be a posi and a 3 series carrier, since buying 3 series gears for 3 series carriers is cheaper than buying 3 series gears for 2 series carriers like yours.
SLP sells a 3 series Torsen assembly for less then $100.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
New2Chevy
Sep 28, 2015 12:35 AM
BOOT77
Sep 5, 2015 03:55 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
