Tranny Mount problems continue
Old May 30, 2001 | 12:40 AM
XxMoLexX's Avatar
Im about to change it again. BUt i have a quick question. I bought a Energy Suspension Urethane mount and crossmember bushings. the other times ive changed the mount i have not taken the crossmember out at all. but it was a big ***********in pain in da *** to push and pull tranny back into position with new mount. Is it okay to take the x-member off to do this? or will this cause alignment issues with the transmission and drivetrain?.
i dont really know wat i wood have to do to correct it if i did end up taking it off and that infact happens.
So please let me know your thoughts and experiences.
Latas and thanks
91 3.1 RS.
T-Tops
12" tube in the "trunk" (That hole they call a trunk anyways)
16x8" ROH Rims
Firehawks all Around
New BOSCH plugs and wires.
Itchin for a SLP Cold Air and new catback.
Dynomax or American Thunder... dunno yet.. suggestions?
Old May 30, 2001 | 06:32 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You could take the x-member off, no probs...
Just remember to support the pan with a jack and a block of wood or you might smash your distributer cap off the firewall.
Old May 30, 2001 | 06:44 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
The x-member will only go on one way. There's a little room for slop, but not significant. With the E/S mount, some have said that it raises the tranny (and it does) so they've put bushings in the x-member to lower it some. I put one in mine, but the angle of the d/s appears to be fine...
KAM
Old May 30, 2001 | 09:22 PM
XxMoLexX's Avatar
I just put in the new mount and bushings... it looks great.. had one tiny problem with the bolt that goes thru the crossmember and into the mount .. the center bolt... it did not fit thru the x-member and i had to make it a bit larger.. but its a pretty damn good fit and i cant believe how much stiffer the shifts are compared to those old rubber mounts.. install was alot easier than the stock kind.
I hope everyone changes over to this someday
Thanks for the help
White 91 3.1 RS.
T-Tops
16" ROH Rims
Firestone Firehawks
Energy Suspension Tranny mount and bushings
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
