Tranny overheating problems? Cure?
Old Jun 1, 2001 | 10:14 PM
JayZ28's Avatar
Ok, when I drive my Z at highway speeds for extended periods of time, about an hour. My tranny shift points go up to like 4k and 5k and I lose OD. First time it happened I got it rebuilt, that was in august. Now it needs it again. Question is if I by one of those deep tranny pans that adds like 2 qts and has "cooling fins" on the bottom (Do they even work?) and I add a aftermarket cooler, will this cure my problem.
Finally, where is the best place to put a temp gauge to get an accurate reading.
Sorry that I rambled, long day at work and its Fri .
Thanxs
speed is a good thing,
more speed is a better thing
86' SLOW LG4 bone stock
except for a K&N
Future Mods: T56
350-383
miniram
Old Jun 2, 2001 | 12:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Make sure your torque converter clutch is locking up. Cruising in O/D for extended periods with the converter unlocked will cause overheating and premature failure.
Old Jun 3, 2001 | 02:00 AM
JayZ28's Avatar
How do you make sure that the Torque converter is locked up?
except for a K&N
Future Mods: T56
350-383
miniram
Old Jun 3, 2001 | 03:18 AM
transfixleo's Avatar
Watch the tach. Depending on the calibration, at some point there will be another 'shift' that isn't a gear change. When you tap the brakes just enough to light the lights you should see the RPM's jump up and then go back down when you let off the brakes again.
Old Jun 3, 2001 | 12:41 PM
JayZ28's Avatar
Okay, I don't think its locking up. what do I do to fix that.
except for a K&N
Future Mods: T56
350-383
miniram
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
mustangman65_79
Sep 1, 2015 03:51 PM
hokis
Aug 9, 2015 03:57 PM
