Rebuilding 700r4
Car: 1991 Teal Green Camaro RS
Transmission: built 700r4
Axle/Gears: 3:42
Rebuilding 700r4
I just got my car back about a week ago from swapping in a stout 350, and was out cruising with some of my buddies when all of a sudden my tranny just gave out. So now Im taking my tranny to be beefed up in order to handle the new 350. Basically what needs to be done in order to have a reliable tranny that wont give out again. Im totally clueless when it comes to transmissions and any help would be greatly appreciated.
Car: 1987 IROC
Engine: 5.0 TPI all stock
Axle/Gears: G92 G80
Re: Rebuilding 700r4
Im gonna do this to mine
http://www.bmracing.com/PRODUCTS/Bui...-not-for-4L60E
If it doesnt work just reload the page.
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
get a nice overhaul by someone you trust. Your make and model transmission is known to be a good one with upgrades, so don't give it away and install a lesser model. Again your year is one of the good ones.
I'd make sure it gets a beast reaction shell as they strip out easy.
a transgo hd2 shift kit
a complete master overhaul kit (all clutches, steels, band etc.) not brand specific just complete
a jr shift kit to rob the updated t.v. valve with return springs
new planet gears if it needs it
a jet servo(tci sells the same one-not the corvette style) it installs easy
a newly rebuilt torque converter
AGAIN MAKE SURE IT IS DONE BY SOMEONE YOU TRUST-hope that helps some, this stuff will complement your year nicely.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I went to all the local builders and asked if I provided all the parts what would he charge for labor
that way you get to put what you want in it like a subway sandwich
Unless someone has already swapped his trans he will already have a 10-vane pump which is just fine for most any build. If you're going to be turning the motor over 5600rpm often, then the 10-vane pump is still fine but needs the heavier slide spring(s) installed to maintain line pressure at the higher rpm.
Engine: 350 tpi
when would you need a 13 vane pump
only asking because I got one and wanted to know if it was overkill
It's pretty much just over-kill. I haven't even used one yet, even in a couple NOS assisted cars that run solidly in the 10's turning rpm's north of 6500. - I know Dana has mentioned several cars that run 10's or better on a 10-vane.
Axle/Gears: 3.36
a 13 vane probably is different thickness, be carefull!!!!!!!! don't just throw it in.. unless ordered correctly it will differ from your 10 vane.
basically all more vanes do is smooth out the pressure pulses because there are more vanes pushing the oil, seven vanes were a little erratic, 10 vanes seemed to be the fix, and 13 was for electronic 4l60e's probably because of all the sensors in the valve body should have a nice steady smooth diet of oil, and the low idles that are common nowadays to keep pressure. IMO don't think 13 vanes are a necessity in anything older, not even really overkill IMO.
3.8TransAM
Sep 27, 2015 08:37 PM
Dragonsys
Sep 25, 2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
