9 bolt vs. 10 bolt - which is better for a performance rebuild?
Old Jun 6, 2001 | 06:28 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I have a feeling this subject has been kicked around a bit, but I looked thru the archives and didn't come up with much.
I'm going to be hitting the scrapyards soon in search of a rear to build up. I'm leaning towards a ten bolt and I need you guys to let me know if I'm thinking in the right direction.
I know 9 bolts are stronger in stock form, but there are lots of parts available for 10 bolts. I'm thinking about a 28 spline 10 bolt with the following:
Zexel- Torsen HD diff.
welded axle tubes
rear end girdle
solid pinion bearing spacer
GM gears
I like the idea of a solid pinion spacer and aluminum girdle. I wish these parts were made for the 9 bolt, but they are not. Will the 10 bolt outlined above match or exceed the durability of a 9 bolt? I don't plan on running slicks or feeding it more than 400 hp.
Jed
89 Formula 350
Old Jun 6, 2001 | 09:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's why I pulled my 9 bolt and built up a 10 bolt with all those above mentioned parts. It's cheaper to build and performance parts are easier to find. Aftermarket 28 spline axles are better than factory 28 spline anyway.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited June 06, 2001).]
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
InfinityShade
Feb 21, 2016 01:29 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
