Question for Pro Built
Old Jun 11, 2001 | 08:25 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
I am trying to reach you about a torque coverter recommendation.I am considering a Continental.What do recommend for my setup?Mods below and I want to keep my rearend for now(3.27 9-bolt).This car is not a daily driver.How much am I looking at? P.S. I plan on a supercharger next year. Thanks for your help.
89 formula 350, 73000k, 9-bolt 3.27, gutted MAF,dynomax muffler,gutted air box,kn,accel 8.8 coil wires,dunlop 60/235
g-tech best(9 runs)14.48@101.1(G-tech records actual speed at 1/4 mile not a true "trap speed" 0-60=5.91
track best(3 runs muncie,in 88 degrees)14.51@96.0 60' 2.089(I found out I had 2 bad injectors and 2-3 gear was bad)
in the garage waiting to go in are alum. L98 heads(bowl job by scoggins-dickey),ported high-flo edelbrock base,SLP runners, Jethot coated SLP 1 5/8 headers,zz3 cam 208/221 .474/510,1LE alum. driveshaft,TCI 2200 stall,LPE feul reg.,TPIS air foil,block .030 over,decked,balaced,ARP main studs,Flowmaster ForceII cat back,Gold crane 1.5 rollers,Eagle forged 5.7 rods,TRW Speed-Pro forged -21cc dish pistons,MSD 6AL,8.5 wires,BlasterII coil,lots of ARP bolts,
Old Jun 12, 2001 | 11:31 AM
Pro Built Automatics's Avatar
How much horsepower (total) do you think you will have once you install the supercharger? If you think it will approach 475 hp or more then I would install the anti-ballooning plates. Your cost for the Continental 10" Apex non-lock up (2,200-2,400 rpm stall)is $414.00. With the anti-ballooning plates your cost is $544.00. If you want to retain the lockup then you could use the ACT 9.5" (similar to the Vigilante) lockup with a stall from 2,400-2,800 rpm. Cost on this torque converter is $545.00. Then price on the Vigilante is about $700.00+. As you see there are different ways to go!
Hope This Helps!!!
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
