pro built shift kit
Old Mar 9, 2009 | 08:13 PM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
pro built shift kit
i had question on the pro built shift kit from dana for my 700r4
i comes with the vette servo correct, but does it come with the outer cover o-ring and lip seal on the vette servo?
also the check ***** - that bag that comes with it includes all the check ***** needed? or am i reusing some steel ***** as well? the seals in there are for the 2 accumulators and the 1 vette 2-3 servo i believe? the one with large and small plate
also where do the secondary filters go?
Old Mar 9, 2009 | 08:46 PM
Engine: 5.7 350 TPI
Re: pro built shift kit
anyone know the part numbers for the cover 0 ring and housing 4th piston o-ring?
Old Mar 9, 2009 | 09:27 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
his kits are usually very complete. that guy knows his stuff. if u have questions and if there are no instructions. call him
Old Mar 10, 2009 | 02:56 AM
Engine: 5.7 350 TPI
i believe i need to buy the servo cover and 4th piston o-rings on my own since i dont see them in my kit as well as the snap rings/e clips
Old Mar 10, 2009 | 03:57 AM
Car: 87 TA clone
i would have thought it came with it. wats the kit that u got, part #?
Old Mar 10, 2009 | 05:06 AM
Pro Built Automatics's Avatar
If you are missing anything? Let me know asap and I will fix this. If you are not sure, call me anyways. Dana
Old Mar 11, 2009 | 03:52 AM
Engine: 5.7 350 TPI
i was missing the 4th piston servo o-ring and the servo housing o-ring i gave my friends transmission shop a call after trying to hunt it down at parts store with no luck. my friend hooked me up with it free
dana- if run into any other problems i give u a call
am almost done all i got to do is install the servos and drill the valve body then put it back up in the trans
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
someone972
Aug 30, 2015 12:52 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
