Differential?
Old Mar 10, 2009 | 11:44 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Differential?
Driving my bird out of state and hit a curb, supposedly snapped the axle at the rear passenger side wheel. Pretty upset I cannot take it to my mechanic, but this auto shop is ordering me a whole new rear end. They said it might have a different differential which would then lead to more work. I dont really understand what it does besides provide power, would it really matter if it was different and if so is it hard to switch my original differential onto the new axle? Thanks, any suggestions and comments much appreciated!
Old Mar 10, 2009 | 12:01 PM
big gear head's Avatar
Re: Differential?
There are many things that could be different. The 3rd gen Camaro and Firebird rear ends had 26 spline axles up to '90, when they went to 28 splines. The gear ratio can be one of about 6, there was the Auburn and Governor Lock limited slip differentials and the standard differetnial. There are different housing ends and brakes. Why are they not just replacing the axle? It would be much easier and cheaper.
Old Mar 10, 2009 | 12:10 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Re: Differential?
they said that if I got an axle it would be 500 and take possibly 3 weeks to get, while the used rear end would take a day andonly cost about 800.
Old Mar 10, 2009 | 12:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Differential?
Originally Posted by kwp289
they said that if I got an axle it would be 500 and take possibly 3 weeks to get...
You can purchase Moser axles from Summit for around $235 a pair and get them within two or three days.
JamesC
Old Mar 10, 2009 | 01:12 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Re: Differential?
I searched google and cant find an axle for my bird. what do you think the outcome of the used rear end will be? i feel like there going to say i need new rear brakes and differential.
Old Mar 10, 2009 | 01:24 PM
JamesC's Avatar
Re: Differential?
I take my back if you're running a 9-bolt. If that's the case, you may have trouble finding a replacement. If you're running a 10-bolt, finding a replacement is as easy as going to Summit.
Who knows what you'll find inside a used rear? The calipers/rotors may need to be replaced. If the gear set is different than your old one, you'll need to replace the drive and/or driven gears in your tranny to make the speedo read correctly. Sounds like a nightmare to me.
If you have a 10-bolt, here's the part number you need (along with seals and bearings) from Summit: MSR-A102604
Note that you can even purchase a single axle.
Oh, and $800 for a used rear end is way out of line.
JamesC
Old Mar 10, 2009 | 01:57 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Re: Differential?
Sorry for not clarifying it but 800 is the total cost including labor.
Old Mar 10, 2009 | 06:21 PM
Re: Differential?
Sounds like you're getting screwed. Why can't they remove an axle from the used rear end and put it in yours? Then you still have your rear end and no problems. What rear end is in your car? What brakes are on it?
Old Mar 10, 2009 | 09:17 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: Differential?
if the hit was hard enough, it may have bent or distorted the flange or the tube and make repair much more difficult
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
dbrochard
Sep 19, 2015 08:13 PM
