700r4 stuck in 2nd gear
Old Mar 10, 2009 | 08:17 PM
krok91gta's Avatar
Car: 91 Formula
Axle/Gears: stock
Hello, I have a 91 firebird 350 with a 700r4. Having trouble with it shifting properly. I just put it in my car, bought it used with 80k miles on it. Worked fine for about 2 or 3 weeks, except for slipping into 3rd pretty bad. Recently it started to skip 2nd and go into 3rd perfectly and 4th. Now its stuck in 2nd all the time. It will go in first if i put it in 1. it'll take about 10-15 seconds to go in first and about 30-60 secs to go back in 2nd when i put it back in D or 2. Anyone have any ideas?? Could it be the ECM or PROM? Thanks in advance..
Old Mar 12, 2009 | 12:12 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700r4 stuck in 2nd gear
Your computer has nothing to do with it. Your trans is failing.
Old Mar 13, 2009 | 07:26 PM
krok91gta's Avatar
Car: 91 Formula
Axle/Gears: stock
I figured, just thought i'd throw that out there. Any ideas on what is causing it to fail?
Old Mar 13, 2009 | 08:16 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
While I have successfully rebuilt a couple of 700R-4s, and I have failed a half dozen more, and read all I could, I'm really not an expert. I have no clue as to what exactly is going on inside yours, but after having 6 of them die under me, and reading about others on several forums, I feel I have this pretty good sense of when it's too late. I could be mistaken, but I'd put money on it being on it's way out.
Old Mar 16, 2009 | 04:37 PM
krok91gta's Avatar
Car: 91 Formula
Axle/Gears: stock
any ideas? the trans fluid smells like burnt rubber or plastic..
Old Mar 16, 2009 | 04:41 PM
TAGTASCOTTY's Avatar
Engine: 408ci Stroker, 520hp 515Ft.Lbs.
Transmission: Outlaw 700r4
Axle/Gears: 3:73
It's the clutch man. Did you adjust the t.v. cable propperly when you put the tranny in?
jklein337
Sep 19, 2018 06:23 PM
NiG
Oct 11, 2015 08:42 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
someone972
Aug 30, 2015 12:52 AM
