TH200 To TH350 in 83 Z28
Old 03-16-2009, 12:14 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
car is an 83 Z28 with a TH200. getting a built TH350 done with the 6" tailshaft. i was wondering if i can use the TH200's crossmember...will the 350 bolt right up? and with the six inch tailshaft i can still use my stock driveshaft right? just making sure... any other parts i need to complete this swap? thanks,
Nick
Old 03-17-2009, 12:07 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
Re: TH200 To TH350 in 83 Z28
anybody? need to know pretty quick here
Old 03-18-2009, 04:32 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
c'mon somebody has to know...ive tried searching i cant find anything on it....
Old 03-22-2009, 12:26 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
please anybody? i really really need to know and i cant seem to find any info on this anywhere
Old 03-23-2009, 01:36 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
TH350 with long tail shaft and a crossmember and you will be good and not even replace the driveshaft. I had a 83 Z28 and I swapped to 700r4 then to TH350 and I was happy with it.
Old 03-30-2009, 05:08 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
i heard that from a th200 i need a six inch tailshaft, crossmember will bolt up and i just need the tourque arm mount...can someone at least verify this?
Old 04-01-2009, 01:37 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
crytical is wrong
the th200 mimics the short 6" TH350 not the long 9"that is similar to a 700r4.
the crossmember is an exact match.
a vacuum line will have to be run.
a new kickdown cable need to be purchased
converter will bolt in the same
all should be good with the 6"er.....
Old 04-02-2009, 03:44 PM
1PimpinZ28's Avatar
Car: '83 Z/28
Transmission: TH200
awesome thanks ed o, as for the tourque arm? i need to purchase a bracket for it correct?
blackz281le
01-11-2016 07:51 AM
13sec83trans
Carburetors
22
11-28-2015 09:26 PM
romcjr
09-17-2015 05:18 PM
89newfun
09-16-2015 09:28 AM
383cam
09-09-2015 06:01 AM
Quick Reply: TH200 To TH350 in 83 Z28
