COuldnt install b&m shifter
Old Jun 18, 2001 | 11:26 PM
Gta-Paladin's Avatar
WEll, it wasnt as easy as i thought it would be i took apart the console and got the stock shifter out then realized i had to pu all these lines in and i didnt have jackstands or ramps to get under the tranny to put the bracket on. So i took it down to a local shop they're gonna charge me an hrs labour like 50 Canadian so 30 american
we'll see if it was worth it tommorow
Old Jun 18, 2001 | 11:46 PM
ws6formula89's Avatar
Old Jun 19, 2001 | 02:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Should've said something, you could've borrowed my jack. I don't know how different the B&M cable is from the stock one, but I've changed the shifter cable on my car without jacking it up.
Old Jun 19, 2001 | 09:22 AM
bhaas's Avatar
I just recently bought one too. It's far from a bolt in. Luckily I have a welder and a chop saw. I used my original cable and just cut the bracket off of the old and new one and welded the old one on. Had to drill out the cable hole about a 64th to fit onto the shifter then I drilled one hole and used one original hole then tack welded the rest in.
I think it could have been made better. And that cable they give you is wayyyy toooo long.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Old Jun 19, 2001 | 11:56 AM
Old Jun 19, 2001 | 12:02 PM
Old Jun 19, 2001 | 01:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, only problem I had with my Megashifter was cutting the console top. I used a cutting tip on a high-wattage soldering iron- it came out good, and I got the bonus of stinking up the basement for a week!
It was definately worth it, though. I used the B&M cable, and even wired up the idle control relay mentioned in the instructions.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 19, 2001 | 03:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My installation was a breeze, for my Dad anyways, since I know just about nothing about working on cars. It took about 3 1/2 hours and the stock cable worked great, didn't even have to get under the car. Just had to drill a hole through the new bracket and use the stock bracket and so far everything is good.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 19, 2001 | 04:22 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I still like the dual gate better...
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
AND IT HAS A NASTY BITE......
CNYFBA MEMBER
http://cnyfba.cz28.com/
Old Jun 19, 2001 | 05:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by Anth's Iroc:
</font>
So do I. The console Dual Gate is about a 1/2 hour install, uses all the factory cables and wiring.
Old Jun 19, 2001 | 11:16 PM
My shifter has 2 cables? wtf one goes down to thesteering column and dissapears and the other to the tranny i could only find one spot to hook it up to the shifter... So i gave up after like 4 hrs and just took it down to a shop... they said it would be a lot of work but they'd do it thenthey called my house 4 times while i was at work maybe to tell me it was ready regardless they locked it up inside.. i went by to see it i barely made anything out from where it was in the shop but i think i saw the chromed shifter ****... heh now im just worried they used that big box that the shifter comes with to mount it on and said f the console but they couldnt have been that stupid could they?
Old Jun 20, 2001 | 12:28 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The cable to the steering column is the park-lock cable. I don't think the B&M uses it.
Old Jun 20, 2001 | 08:14 AM
Steve10's Avatar
Is the dual gate a Hurst? Is it a ratchet type? Does it install that easily into a Firebird? I have a brand new unopened Mega Shifter from Summit sitting in the garage, just haven't had the time to install it. Frankly, after reading all the negative posts I'm really dreading the install and I'm thinking about exchanging it for something easier. Opinions?
'87 Formula WS6 - ZZ4 TPI, ported heads, LT4 hot cam, 1.6RR, SLP runners, Accel lower, ported plenum, Edelbrock 58mm TB, pulleys, SLP cold air, headers and full exhaust, Koni yellows.
Old Jun 20, 2001 | 10:23 AM
Old Jun 20, 2001 | 01:02 PM
alright so they bolted it up fixed some **** in the tranny for me... I LOVE IT i bought the megashifter with a hammer handle it feels so sweet, it's sitting in my driveway right now i like the way the Chrome burns your hand if you dont coverit... the B&M doesnt use the steering columcable. It took a 10 min drive around to get used to having to slam it up that hard im loving the no skip shift and the reverse lockout have to be in neutral to go into park or reverse.. Now all i gotta do is hook up the console. Any recommendations? Should i cut the little bar off of the top of the shifter? or cut the ashtray?any suggestions?
Old Jun 20, 2001 | 01:06 PM
Steve, the shifter is the best thing since sliced bread, frankly i wouldnt have changed a thing. The only problem is the console everything else can be done relatively easy.. but it's time consuming i just got someone to do it for me because im scared of tranny's It looks and feels great i'll get some pics up soon
Old Jun 20, 2001 | 01:08 PM
ws6 da_bozo@hotmail.com
sonaht@homtail.com i might need htose
Old Jun 20, 2001 | 02:06 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
camaro11j
Sep 19, 2018 08:49 AM
neekolzun
Aug 24, 2015 04:59 PM
crazynights
Aug 21, 2015 06:53 AM
Dialed_In
Aug 20, 2015 01:45 PM
