most mileage out of the 700R4??
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
just curious as to who has seen a 700R4 behind any kind of V8 last more than 120K???
my dad has a 90 s10 with the 4.3 and 700r4 and it has 268,xxx miles and still going strong.
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Car: 82 camaro SC
If it's taken care of: fluid changed, leaks fixed, never run it low, never overheated, and auto will last a long time. I've seen 200000 out of a 700r4 and still running strong.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 93 S10 blazer
probably going to be bad luck if I say this but I got 122,000 on my 700r4 and it is not a hand grenade yet even with the a built motor I bolted it up to 18,000 ago.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
1990 TA 350 TPI
SPORTSMAN II HEADS
52MM THROTTLE BODY
24LB INJECTORS
my 700R4 has seen 3 different motors, 150k on the first one, about 80k, on the second one, and about 9k on the current engine. its just now starting to have problems engaging into gear. i have to put it in 2nd to get it to go into forward gear when its cold. other then that it runs fine. and its seen alot of abuse.
My 700R4 has 130,000 miles on it and have not had any problems with it. My 350 TPI is putting nearly 300HP to the fly wheel. My car gets driven hard every day.
You will get a lot more life out of your trans with a trans cooler installed. This is one of the mods I plan on doing very soon.
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
Best 60ft. 2.07
I blow one up about every 20,000km. I have very bad luck with them. My first Z28 was owned by a lady and I bought it with a factory replacement in it. It had 266,000km on it and the motor has 350,000 and still going strong. I just can't get luck with them. Our work trucks eat them about every 100,000km but we have never done anything else to them other than tranny work.
Transmission: 4L80E/4L80E
Camaro has 141k. '84 G20 Chevy van has 125k, last 45k it's been pulling a two-horse trailer regularly. No problem with either one.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
this is great news guys.
mine has been doing ok but when I got it at 54k it would regularly chirp into 2nd even at light throttle (trans cable misadjusted).
since about 80k the trans wont chirp the tires anymore (partly the new posi) and now I have 120K and the 2-3 shift is pure slush. the 1-2 shifts hard but I cant chirp even if I redline it.
I had a flush (100%) at 67k and nothing since then.
how much longer do you think I have behind a ~270HP 305????
and I do NOT take it easy. (dont think I know how!)
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
SSM SFCs, Bilsteins
check it out at:
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
