transgo shift kit? please read and inform
Old Jun 26, 2001 | 12:56 AM
RARE-ROC-Z's Avatar
ok my friend won this at a car show. but he drives a ford probe. so he said that he would sell this to me. i know that he is getting $50 profit but i dont care.
the box says "psx 700" so it is specialized to the 700r4, are all the stages in the same box, or are there different stages? i know nothing about shift kits if you can help please.
what does it do, i know it makes the trans shift stronger, but mechanically explain please.
thanks, and i have seen the install of a B&M kit and i really dont like these, but how much harder is it to install the Transgo?
thanks and sorry if i am asking too much.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Interior
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE.
Old Jun 26, 2001 | 04:16 AM
transfixleo's Avatar
I hope this helps:
First off, what a Shift Kit ISN'T. Most people associate the term Shift Kit with tire chirping shifts. Actually Shift Kit is a trademarked name coined and owned by TransGo Since 1959. The purpose of a Shift Kit is to correct the weak points of a given transmission. In most cases when someone complains of soft or slipping shifts it isn't BECAUSE if these complaints that they fail but rather there is a malfunction that leads TO the burned/glazed frictions and the poor shift quality is the result. There are many kit's out there designed to give you firm shifts but if that isn't the cause of your problem it isn't fixing them.
For example, in a 700 you have problems with delayed pressure rise which allows the clutches or band to slip until the pressure catches up. If you don't fix this, it doesn't matter if you put the Vette servo in or the .500 TV boost valve or not. They will only mask the problem. This problem is there whether it is a grocery getter or 5.7 IROC. The TransGo Shift Kit corrects this and other problems that these have. This kit however isn't available to the general public because of the technical knowledge required.
They do however have something that I think most of you are after though. It is called a Reprogramming Kit or also a High Performance Shift Kit. It has the basic fixes that the Shift Kit has and it has features to give the tranny HD/HP capabilities such as greater manual control and higher horsepower and torque handling ability. The 700 kit also includes some pieces for when the unit is O/H'ed to give it higher RPM capability (at higher RPM, residual oil can drag the 3-4 clutches on even when they should be off). This kit (the commercial version) has a video to aid in the installation too.
Old Jun 26, 2001 | 12:23 PM
RARE-ROC-Z's Avatar
thank you so much man. i was wondering. but where can you get the noncommercial kit?
and i think i will get this kit if it has a video. we havent opened the box yet so..
thank you so much.
Jarrad
TH-700R4
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
