Automatic Transmission Shifters
Old Jun 21, 2001 | 10:06 PM
85maro's Avatar
Does any one use the Hurst Dual/Gate 2 shifter for automatic Trannys. I am very in terested in it. And i would like to have comments from people and how they like theirs. Thanks in advance!
http://www.yearone.com/nextgenparts/...iveline66.html
Just scroll down and youll see it.
Old Jun 22, 2001 | 04:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try doing a search on this board, there's been a few topics with discussions of the Dual Gate.
Old Jun 22, 2001 | 06:32 AM
ede's Avatar
ede
i have a quarter stick by hurst in my car. there isn't a better shifter made. you can't miss or over shift a gear and if you want you can put it in drive and go.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 23, 2001 | 09:57 PM
85maro's Avatar
any other comments?
Old Jun 24, 2001 | 04:45 AM
Gta-Paladin's Avatar
ede is lying the B&m megashifter is better
because uh, essentially it's the same thing
but its a bitch to install on any bird
Old Jun 24, 2001 | 11:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Quarter Stick is nothing like the Megashifter, or the Dual Gate for that matter. The Quarter Stick is more of a real racing shifter.
Old Jun 24, 2001 | 01:27 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I want to be able to shift my automatic, and have it shift right on. No stupid delays. Thinking B&M Megashifter and do I need some kind of shift kit too?
Old Jun 24, 2001 | 02:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All the shifter does is prevent you from overshifting, you'll need a shift kit for what you want.
Old Jul 1, 2001 | 07:54 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
after removing my busted-az stock shifter and cable and put in the B&M mega shifter,I noticed the transmission responded much better to shifts,it seems to "pull" better in each gear too,maybee because the lever isn't slopping around on the trans anymore. ofcourse a shift kit will crisp things up some more.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
