worn clutch pushrod question
Old Jun 26, 2001 | 07:57 PM
nestz28's Avatar
Hi, any help would be appreciated here. The eye in the puchrod that attaches to the clutch pedal is worn so that the clutch won't fully disengage, so shifts are really hard. My question is whether I can take the pushrod out to get a new one or put a bushing in it or is it attached to the master cylinder? I've tried to pull it out and it seems like it is attached but I wanted to check before I replace everything. Thanks for any help.
'84 Z28 LG4 T-5
'92 Z28 wheels
153,000 miles
Front& rear suspension rebuild using MOOG parts
350 and WC coming in summer 2001
'70 nova 307, th350, all stock, 40,000 mi almost like new
Old Jun 28, 2001 | 01:07 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I think you've got bigger problems than just a worn master pushrod. you may have air in your system causing the clutch to not fully disengage. I don't know that you can change just the pushrod. You can go to the parts store and buy a new master cylinder for around $65 or so. If I were you, I'd see if bleeding the clutch hydraulics will cure the problem. If that cures it, may be able to live with the extra slop in the lingage. If you're like me and want to change it regardless, so be it.
email me if you have any questions, sometimes my explanations don't come across so well
OH, and I just saw your sig. I'm BUILDING moog parts as we speak!
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited June 28, 2001).]
Old Jun 28, 2001 | 10:35 PM
nestz28's Avatar
Thanks for the reply, I'm gonna try a new pushrod and see if that works and then go from there.
Old Jun 29, 2001 | 10:22 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Did you find just the pushrod? I'm just curious. I think you are going to have to do some disassembly of the master cylinder in some pretty tight confines to do it (if it's reasonably possible). I haven't messed with my clutch system in awhile (the car hasn't run in the last two years). I'd love to know how it all goes though.
Clem
Old Jul 3, 2001 | 11:27 AM
nestz28's Avatar
Yeah I found it and after I decided that if I broke it I'd just buy a new one, I popped the old puchrod out with a pair of pliers. I went to the junkyard and got one off of a V6 camaro and it works well now. The hole where the rod attaches to the clutch pedal was slightly elongated causing too much play. Thanks for the help.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
