Code numbers on 10 bolt housings?
Old Jul 4, 2001 | 11:57 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I need to find an F-body 7.5" 10-bolt housing at a bone yard this week. I have 28 spline axles, a new Auburn posi, and the parts for a rebuild except the housing and gears (would like to find 3.23 or 3.42 gears). Anyone know what the code numbers are on F-body 10-bolt housings w/ 28 spline axles? Are the housings different widths for F-bodies than other GM cars? Will the number on the housing be different for different gear ratios?
Old Jul 5, 2001 | 01:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, if you just need a housing and gears, check out 85-89 2.8 V6 F-bodies, with automatic transmissions. They got 3.42's. Spline count shouldn't matter at all; since you already have the posi and axleshafts, you can slide that stuff into the junkyard housing. The 3.42 gears are 7.5" rings, so I'd imagine they'd fit onto your posi carrier without a problem. Pull the diff cover and check 'em out before you buy the axle.
Oh- the strength of the gears in the V6 axle are equal to that of all f-bodies, including the V8's. In fact, if you manage to find a 4-cylinder 2.5l f-body, give it a good look- it could be hiding 3.73 gears!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited July 05, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
blackd-out z28
Aug 15, 2015 08:18 PM
