8.5 ten bolt question
Old Mar 29, 2009 | 01:59 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay so i have a friend with a 78 camaro. It has a 8.5 ten bolt in it that hes getting rid of for a 9".
i know it is set up for leaf springs, but i know I can fab it to take my springs and shocks on it, but the HARD part is the torque arm correct.?????? It needs to be dead on accuracy wise.
Has anyone done this here? I searched but the search tool sucks something serious right now.,
Also does anyone off the top know how much wider or shorter a 78 rear is compared to a thirdgen diff or 4th gen diff
Old Mar 29, 2009 | 02:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8.5 ten bolt question
I think second gens diffs are wider.
As for the torque arm mount, it has been done but a lot of fabrication work needs to be done. It can be a lot cheaper and easier to just buy an aftermarket bolt in diff.
Old Mar 30, 2009 | 12:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I recall a 2nd gen rear being 3/8" narrower. Or something like that, I believe it was a hair narrower.
Moving brackets over should be easy, but as you've already determined, the Torque arm will be tricky.
There are many schools of thought for this, so be sure to tell us how you decide to go about it.
Old Mar 30, 2009 | 02:59 AM
rippin ron's Avatar
Car: 91 Camaro RS
Axle/Gears: 4.10
The tricky part is welding to the cast diff.
Old Mar 30, 2009 | 08:04 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya I was curious if someone had any tips for that torque arm part
I mean it's a free 8.5 so what's the hurt
Old Mar 30, 2009 | 08:08 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
If you have the fabrication skills to do it then go for it. If not you are going to be spending a good chunk of change to have someone else fab up the mounts for you.
Old Mar 30, 2009 | 12:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'd do it, if it were me.
If/when I destroy my 7.5", this is the route I will take.
Either machining a TA bracket and brazing it to the cast, or pre-heating, and using a ~95% nickel-rod and welding it on. Either way I think it's a good option...
Old Mar 30, 2009 | 01:27 PM
Shagwell's Avatar
Car: projects.......
There's a recent thread on here about using an 8.8 ford. I posted pics of how I built a torque arm suspension using it.
Old Apr 1, 2009 | 09:08 AM
big gear head's Avatar
The second gen Camaro rear end is 61 inches wide overall. This is going to take a lot of work, as you already know.
Old Apr 1, 2009 | 09:21 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I'll look maybe if you have the link just pm too cuz I can get a 8.8 for a 100 bux
Old Apr 1, 2009 | 09:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Big gear head, what's our overall width?
I want to say some members on here have done this, and mentioned that the second gen is less than half an inch narrower. I cant for the life of me remember who it was though...
https://www.thirdgen.org/forums/fabr...axle-swap.html
https://www.thirdgen.org/forums/tran...n-10-bolt.html
I can't search via 8.5" because it's a number... frustrating... As per sofakingdoms post in the above thread, I may be wrong!
Old Apr 1, 2009 | 10:27 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Here are a few pics I saved from a 8.5 build someone did on this site. I dont know who did it
Attached Thumbnails 8.5 ten bolt question-torque-20arm-20mount-2001.jpg   8.5 ten bolt question-torque-20amr-20mount-2005.jpg   8.5 ten bolt question-torque-20amr-20mount-20011.jpg
Old Apr 1, 2009 | 10:30 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
A couple more pics if the mods dont mind.
Attached Thumbnails 8.5 ten bolt question-torque-20amr-20mount-2004.jpg   8.5 ten bolt question-torque-20arm-20mount-2002.jpg   8.5 ten bolt question-torque-20arm-20mount-2003.jpg
Old Apr 1, 2009 | 10:37 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Not sure on these pics, and not sure what rear, but might use the pattern.
Attached Thumbnails 8.5 ten bolt question-rear-end-pics_0217.jpg   8.5 ten bolt question-ian-27s-20pictures-20133.jpg   8.5 ten bolt question-rear-end-pics_0219.jpg
Old Apr 1, 2009 | 11:13 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
decided on getting a 8.8. im looking in to two designs for a torque arm mount.
Those pics are VEry helpful. Thanks!!!!!!
Old Apr 1, 2009 | 11:15 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Your welcome!
Old Apr 1, 2009 | 11:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Nice thing about the 8.5" is that the wheel bolt pattern is right.
With a Ford 8.8" you'll need custom axles, or mustang wheels.
Just a heads up.
Old Apr 1, 2009 | 12:08 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have double pattern greg welds
They'll fit mustang bolt pattern
Old Apr 1, 2009 | 03:47 PM
Shagwell's Avatar
Obviously you don't need to, but you could also re-drill the flanges for the GM 5x4.75 pattern/
The 8.8 is stronger stock and stronger with the aftermarket support. It is on par with a 12-bolt.
Old Apr 2, 2009 | 12:07 PM
I can't remember what the total width is on the 3rd gen rear ends.
84z96L31vortec
Aug 20, 2017 12:16 AM
sailtexas186548
Jan 19, 2016 12:21 PM
z28_AJ
Aug 27, 2015 08:59 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
