T-5 reverse
Old Jul 6, 2001 | 05:57 PM
Mike92RS's Avatar
T-5 reverse
Are there supposted to be synchros for reverse in the T-5? Just wondering if my T-5 is messed up or if that's how it's supposted to be. Also, it makes a humming/whining noise while cruising, higher pitched the faster you go. Not really loud, but definaly noticable. Is this normal too?
- Mike
Old Jul 6, 2001 | 07:59 PM
84TransAm's Avatar
I'm fairly certain there's a synchro to Reverse, but it is weaker than the rest so it wears out faster. I avoid the grinding noise by pressing the clutch in, shifting to 5th and then to reverse. Also, check the fluid level, that can make a high pitched noise.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
Old Jul 6, 2001 | 09:07 PM
OLDYELLR's Avatar
Car: '85 IROC
While only a few very exotic cars used to have a synchro reverse, it's more common now. However, I don't believe the T-5 has it. If it grinds, the gears are probably spinning from a bit of clutch drag. Just put it in another geat before going to reverse.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Jul 7, 2001 | 03:49 AM
AntiVTEC's Avatar
T-5's dont have reverse syncs.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
