1987 IROC w/ 3.45 Borg Warner. HELP
Old Jul 17, 2001 | 11:39 AM
telstar's Avatar
Hey guys and gals,
My 1987 Iroc with stock Borg Warner rear end has developed a noise... Howl actually!
While driving, the rear end howls under power or accelerating. When I lift my foot off the gas pedal, the noise goes away... What does this mean? Who can I turn to for parts to repair??
Thanks!!
Old Jul 17, 2001 | 11:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably a bad pinion bearing...
Parts should be available most anywhere that sells bearings. Fix it before the misalignment damages the gears. Unfortunately it's alot of labor to have to pay for if you can't do it yourself. I'd recommend replacing all the bearings while you have it apart; that would be both pinion bearings, both axle bearings, and the carrier bearings.
Most of the time, this is caused by running it dry, or by having water in the fluid.
ICON Motorsports
Old Jul 18, 2001 | 07:56 AM
ausrs's Avatar
excellent advice the only real prob with the 9 bolt is the pinion bearing ...just put it into a shop and get them to replace all bearings and re lap gears in
Old Jul 18, 2001 | 08:30 AM
telstar's Avatar
You guys are great!
Thanks so much for all the input... I feel better now...
Sean
Vojtush31
Oct 11, 2015 01:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
transamgta87
Sep 1, 2015 07:07 PM
jharrison5
Aug 19, 2015 05:53 PM
telstar
Jul 17, 2001 12:59 AM
