Is it safe to drive with broken tranny mounts? How hard are they to fix?
Old Jul 14, 2001 | 11:55 AM
Xenodrgn's Avatar
Topic says it all. And if you could give me a write-up on how to fix the tranny mounts, I'd be very thankful, my Chiltons doesn't give very good directions.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Jul 14, 2001 | 12:10 PM
Xenodrgn's Avatar
I think I should also mention, my tranny is shot (fluid brown, still shifts ok -most- of the time, but can get gay). Should I just wait to replace the mounts when the tranny gets done, or what?
Old Jul 14, 2001 | 12:50 PM
Xenodrgn's Avatar
Doh, my bad, I just saw the tech article on this very same subject. Sorry. But still, is it still safe to drive?
Old Jul 14, 2001 | 06:07 PM
rabidfool's Avatar
While i dont know about the safety aspect of driving, i can recomend a good mount. Goto jegs.com and order their energy suspensions' mount. I bought a 91 z28 back in feb and have blown two mounts since. I had my mech put in the energy suspension one and it has worked great since. The part itself costs about $28 shipped from them, and you can get them in designer colors! (as if that matters, but i still got the red one to match my car.)
Old Jul 15, 2001 | 01:47 PM
Xenodrgn's Avatar
Just so you know, Summit carries whose same mounts for 20.95, and thier ground shipping is free. If you live on the coasts, you'd get the parts in 1 to 2 days.
Just a little FYI
Old Jul 16, 2001 | 06:45 PM
Dumperbird's Avatar
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
You don't wanna drive on a shot mount cause it will mess up your drivetrain. The mount is what keeps you tranny from jumpin around like a grasshopper. if you mash the gas and get good traction you can mess up your driveshaft and the tranny.
You put Mt. Dew in the gas tank!?!
Wow, look at it go!
Old Jul 17, 2001 | 01:47 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dumperbird:
You don't wanna drive on a shot mount cause it will mess up your drivetrain. The mount is what keeps you tranny from jumpin around like a grasshopper. if you mash the gas and get good traction you can mess up your driveshaft and the tranny.</font>
Thats what I thought, thanks for backing me up. lol, maybe I shouldn't have demonstrated to my g/f last night the extent of my car's broken'ness. :P
Old Jul 17, 2001 | 02:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
Just a little FYI
</font>
Plus $6.95/order handling fee. Sounds pretty close to $28 to me...
Old Jul 18, 2001 | 11:44 AM
91z4me's Avatar
Well I just had one fixed in my car. Before I did it if you were to mash the gas the tranny would jump up and hit the floorpan. Also it would break the rear tires loose. I paid 85 for a shop to fix mine. If you do it yourself have something to support the tranny for when you pull the mount. This is also a good time to check all the front suspension for wear tear and damage.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Jul 18, 2001 | 12:47 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I just used my floor jack on the torque arm near the cross member and removed the cross member and put the mount in. Took more time to put the front of the car on jack stands.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 18, 2001 | 07:45 PM
Dumperbird's Avatar
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
</font>
That's about how I felt too. Next time... ramps
Wow, look at it go!
1984 L69 305HO WS6 Firebird Trans Am
Current Mods[*] 2 1/2" Flowmaster cat back[*] gutted cat[*] 160 thermostat[*] all around polyurethane bushing kit from Energy Suspension[*] 3.73 Disk rear
Mods to come![*] 350 .30" SB [*] Comp Cam[*] Edelbrock RPM Proformer Package [*] 3.73 Posi Disk rear[*] Edelbrock TES headders - Yeah I like em![*] 150 lb shot Edelbrock Nitrous System[*] Edelbrock Aluminnum Signeture Series Valve covers.[*] 140 amp GM High Proformance Altnator
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mcquigg
Aug 13, 2015 02:26 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
