Transmission Mount?
Old Apr 9, 2009 | 11:38 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Transmission Mount?
The other day I was driving and I downshifted from 2nd to 1st then floored it and I felt and heard a noise right by my arm rest. Now when I try to floor it in any gear I get the same feeling and noise. I'm assuming it's the transmission mount, just need some reassurance.
Old Apr 9, 2009 | 11:40 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Re: Transmission Mount?
possibly... crawl up under there and check everything just to be sure thats all it is...and how fast were you going when you went into 1st.??
Old Apr 9, 2009 | 11:42 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
is your shifter moving up and down.....probably is the trans mount...very weak and common problem...I'd bet ya your right on..bad mount..
Old Apr 9, 2009 | 11:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
20+ year old rubber mount. If it doesn't need replacement, it will.
JamesC
Old Apr 9, 2009 | 01:52 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
I was going like 25 when I dropped it down to 1st. I have no problems with my shifter, it only happens when take off fast.
Old Apr 10, 2009 | 08:20 AM
redCamaroblack's Avatar
Car: 1985 Camaro
Engine: 400sb
Transmission: 700r4 auto
Axle/Gears: posi trac, gears??
Yea, its your mount. I had that smae problem and didnt fix it. Now my tranny is screwed up and I cant drive it...
Old Apr 10, 2009 | 02:51 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Damn man. I'm probably gonna fix it tomorrow.
Old Apr 10, 2009 | 11:56 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
how did it screw up your tranny. BTW i got an energy suspension mount and it is about a 3/4 of an inch taller, is it supposed to be that tall? Also when i put it in i had to pry the tranny back over so it was in proper alignment.
Old Apr 11, 2009 | 04:42 AM
88Roc-z's Avatar
Car: 88' Iroc-z
Transmission: T-5 WC
Axle/Gears: 3.73 9-bolt
Just curious, but does both the T-5 and auto take the same tranny mount? I got a 88' and I was planning on either using Energy suspensions or Prothanes one thats why.
Old Apr 11, 2009 | 03:24 PM
Race Ready's Avatar
I have an 86' trans am with a 305 H.O. 4bbl with a 5 speed. I Think a similar thing happened to me. From a stop I burned out through 1, 2nd, and 3 Gear and I felt somthing bump the floor when I floor it. How easy is the fix? Is there a stronger replacement. Oh and a side thought I have heard that my car is rather rare. With is also being a ws6 and a borg & warrner trans and axle. Is this True???
Old Apr 11, 2009 | 03:33 PM
JamesC's Avatar
https://www.thirdgen.org/trannymount
Poly.
JamesC
Old Apr 11, 2009 | 11:29 PM
Car: 1985 Camaro
Engine: 400sb
it wont accelarate fast, and if I try to it doesnt shift and just floats there
Old Apr 12, 2009 | 07:27 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
It was the tranny mount, thanks for the quick responses.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
