transmission slipping?
Old Apr 12, 2009 | 01:16 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
it happened before one time but it revs up to 3500 rpm's before switching gears, i just need her for another 3 months and i just put $900 into her for a rear end. the transmission fluid is overly full. any suggestions of what might be causing this problem or what I could do?
Old Apr 12, 2009 | 01:18 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: transmission slipping?
either the clutch pack and bands are bad in the transmission. or you're torque converter is bad. NOW lol might be even simple as ur detent cable is needed an adjustment. assuming its a 700r4
Old Apr 12, 2009 | 01:25 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
i dont even know, any instructions to check?
Old Apr 12, 2009 | 01:28 AM
berlin305's Avatar
know what? do you have a 700r4 transmission? okay is this car stock and is it auto?
Old Apr 12, 2009 | 01:34 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
as far as i know it is stock and an automatic.
Old Apr 12, 2009 | 01:40 AM
berlin305's Avatar
ok then its the 700r4. okay the detent cable is located where you're throttle body to accelerate. it will look black and will have a tab on it to adjust kinda hard to explain w/o pictures. they have info on this let me see if i can find it and then link it for you. that is the easiest and probably what needs to be done and if it don't work then i be looking for another tranny. or just keep fluids in. assuming its leaking. if not try put trans X in it. ask a local parts store they know what it is. works great on worn transmissions brb for the info to adjust it.
Old Apr 12, 2009 | 01:46 AM
berlin305's Avatar
https://www.thirdgen.org/forums/tran...djustment.html
that is how to adjust.
Old Apr 12, 2009 | 01:51 AM
berlin305's Avatar
okay B). is a D shape cylinder press that in and hold it. D) is the cable take it off the throttle body and slide it all the way in its the green tab looking in the picture. then. release the Button on figure B. then slowly slide the cable out to connect to the throttle body make sure you have the throttle body at the positon do not move it yet. Next get in the car and step the accelerator and floor it slowly all the way to the floor hold it until it stops clicking. And you are done adjusting the detent cable.
Old Apr 12, 2009 | 01:53 AM
berlin305's Avatar
to clarify the info on the throttle body do not move it leave it as where it is just disconnect the green tab maybe black on urs. and then when you slide it back thru the cable release the D looking button and pull it out slowly to connect where you took it off.
Old Apr 12, 2009 | 11:54 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
mine is a tpi, looks completley different frm the picture
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
camaronils
Sep 20, 2015 02:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
