Little confused has anyone else did this????
Old Apr 12, 2009 | 06:35 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I found this on third gen? https://www.thirdgen.org/torqueswitch is all stock stalls not lock ups? Will this work on my 305tbi? If so will some one else kinda of explain it?
thanks
kevin
Old Apr 12, 2009 | 08:05 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Little confused has anyone else did this????
If you have a lockup convertor this will work for you , your car being a '90 it should be a lockup . what this does is over rides your factory lockup so you can lock it when you want but with the switch off it will opperate as normal .
Old Apr 12, 2009 | 09:18 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
All 700R4s have lockup converters stock, going back to the first one in 1982. This system allows you to lockup the converter any tiem you want. Typically the 700R4 only locks up in 4th gear at cruising speed. A locked converter is more efficient and uses less fuel. This system allows you to lockup the converter in other gears like if you are cruising in the city at 25MPH and only in 3rd you can lockup the converter to get better fuel milage.
Old Apr 12, 2009 | 09:28 AM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
so what happens if you have a stall converter?
will this still work if the car was a TPI but is now a Carb and all the wires from the original harness (well almost all) are cut and tucked down inside the fender?
just to be sure... this is ok to race with it on?
can you turn it on while moving or do you have to be at a complete stop before engaging?
Old Apr 12, 2009 | 09:37 AM
Will it make the car launch alot harder?
thanks
kevin
Old Apr 12, 2009 | 09:55 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
It will work on a stall converter if it is a lockup style . Not shure on the wireing I would think the lockup control would be seperate from engine harness . The link on how to do this says he raced with it . you can turn it on while moveing because when it usually locks up is in 4th when you are driving .
Old Apr 12, 2009 | 10:00 AM
Car: 1985 IROC Z28
i know it "says" he raced with it, LOL, but i'm asking if its "ok" to race with it..... so, how do i find out if it's a lockup converter i guess is the next question...
Old Apr 12, 2009 | 10:09 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
As with any raceing it can be hard on the trans . If you have an electrical plug on your trans it is lockup and if i'm not mistaken you have to replace a lockup converter with a lockup converter even if it is a stall converter .
Old Apr 12, 2009 | 10:17 AM
Well you guys said it will work on my car! Where do the wires go? That what i dont get?
kevin
Old Apr 12, 2009 | 10:25 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
kevin
They connect to the upper left and upper right pins of the diagnostic port .
Old Apr 12, 2009 | 10:27 AM
Sorry but still learning. Where is that located?
thanks alot
kevin
Old Apr 12, 2009 | 10:29 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
thanks alot
kevin
It is under the driverside dash it has a little cover over it neer the dashpod .
Old Apr 12, 2009 | 10:33 AM
oh ok i know what ur talkin about now.
thanks alot
kevin
Old Apr 12, 2009 | 10:55 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
You are very welcome .
Old Apr 12, 2009 | 05:12 PM
Ok i did it and i felt it bog down then it wouldnt really move? Then in 3rd and 4th couldnt really tell any thing? Did i do something wrong?
kevin
Old Apr 13, 2009 | 08:15 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
The guy in the link only talks about second so that may be the only gear you can fell the difference in .
Old Apr 13, 2009 | 08:47 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
You will not feel much of a difference because it only drops the RPM about 300 RPM. The lock up is designed for fuel economy and increases the efficiency of the transmission.
You want to only use the lock up when you are at a cruising speed in a high gear (3rd or OD) and DO NOT try and use it when taking off.
Some people use the lock up for racing. I have done this many times in my Turbo 6 cars. The TCC will not work at WOT in a stock car. The trick is to manualy lock it in hight gear (3rd) to help increase the amount of power to the tires (reducing slipping in converter) and helps with ET about a tenth or so. Keep in mind this is really hard on the TCC and will make it wear out a lot faster.
To determine if yours IS working watch the tach when you turn it on and off at a constant speed/rpm and see if the tach moves up and down a few hundred RPM. If this is the case it is working. If you have a factory car and everything is original you can test the TCC by pressing light on the brake pedal when driving a constant speed (do not ket off the gas) and see if the tach raises a feww hundred RPM. When you let back off the brake it should decrease RPM.
Hope this helps!
Old Apr 13, 2009 | 08:58 AM
It was working but it just felt like my car was slower?
kevin
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
