2.73 @70
Old Jul 18, 2001 | 03:10 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
2.73 @70
For those of yall that have the 700r4 and 2.73 gears what rpm do you turn at 70mph in 4th. I turn like 2100rpm. Gear calculators say that I have a 3.23 but I dont.
Old Jul 18, 2001 | 04:17 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
2.77 @ 2000 rpm = 77-78 MPH
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 18, 2001 | 07:01 PM
82camaro's Avatar
Car: 82 camaro SC
With the correct input, the calculations don't lie. Double check all your numbers. Then you have to consider:
torque convertor locking up?
tach a little bit off?
speedo a little bit off?
verify the gear ratio by counting the teeth?(someone could have changed the gears)
tire height can vary from brand to brand(did you use the advertised size of the tire or the actual measured height?)
What size tires do you have?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 18, 2001 | 08:31 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
I checked the tire size several times 25.5
Torque converter is locking because when I tap the brake rpms jump up 100rpm or so but I guess it could still be sliping some.
I counted the gear teeth two times then my wife counted them 15/41 That is 2.73 right?
I dont think my spedo. is wrong but I cant be sure.
My tach ????? most likley, how do I test it without learning to count really fast
Old Jul 18, 2001 | 11:09 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">93 Civic 1.6L
13.5 @ 100 mph</font>
That's a fast civic! What did you do to it?
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old Jul 19, 2001 | 11:29 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
My 91 RS with 16" 245/50R16 Tires and 2.73 gears ran 2100 rpm at 70mph. New 3.42 gears with same tires runs 2700 rpm. According to factory tach anyway.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 22, 2001 | 08:56 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
75mph approx. 1950rpm. 700r4 and 2.73's
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Jul 22, 2001 | 11:53 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
2.73s 70@1900
80@2000
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro.
Old Jul 22, 2001 | 02:07 PM
Omar's Avatar
Like 82camaro said, is your stock tach off? They are not very accurate. Mine is off about 300rpms.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 22, 2001 | 02:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
are you sure you put in tire radius, and not tire diameter? that will throw the calculations way off...
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Jul 22, 2001 | 03:48 PM
MouseCamaro305's Avatar
if youre cruising at 75 MPH in D youre tach will actually show you what rearend youve got. 2.73=2,730 RPMs 3.73=3,730 RPMs etc.
Old Jul 22, 2001 | 06:45 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
D isn't 4th its third, right?
Old Jul 22, 2001 | 07:29 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Yea, "D" is third. I don't get to 2000 RPM until I reach about 83 mph. That's in OD with a 700R4 and 2.73s.
64Chief
Sep 12, 2015 08:05 AM
john204481
Sep 7, 2015 03:22 PM
Warlocksirix
Sep 3, 2015 12:26 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Regal105
Aug 23, 2015 03:45 PM
