Guys with A B&M MegaShifter
Old Jul 31, 2001 | 02:51 PM
DeathZ's Avatar
How hard is to install? Do you have to use a diffent shifter cable? Do you have pics just want to see what they look like. Thanks
Old Jul 31, 2001 | 03:00 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Installation is a snap, pretty strait forward. Yes you have to use a different shifter cable,but it is included with the shifter when ya buy it. Watch out when you hook up your back up lights to the switch they send ya,sometimes they make your back up lights burn all the time. Just check to make sure they are no burning all the time before you get it all bolted toghter. If they burn all the time,take a screw driver and bend the metal on the switch out a bit and it will fix it. That was the only problem I ran into on mine.
Old Jul 31, 2001 | 03:10 PM
DeathZ's Avatar
Doesnt it have a light display to tell you if your in drive or park or whatever?
Old Jul 31, 2001 | 07:10 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Yea it has an indicator telling you what gear you are in. I didn't have any major problems with the installation of mine, it took about 6-8 hours. If you want to see what it looks like check out the pics on my website of my interior.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Jul 31, 2001 | 11:00 PM
Jza's Avatar
Jza
Bend the switch? You do know those holes are elongated so you can adjust the switches, right?
Old Jul 31, 2001 | 11:12 PM
Gta-Paladin's Avatar
Dont get it if you have a t/a with power mirrors PITA
Old Jul 31, 2001 | 11:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You don't have to use the shifter cable they give you, I used the stock one and never had to get under the car.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 1, 2001 | 09:51 AM
bhaas's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
</font>
Me either. Piece of cake. That cable is wayyy toooo long.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Old Aug 1, 2001 | 01:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used their new cable and had no problems... I looped it over the trans as showed in their directions. The shifter was cake, for me, the hardest part was cutting up my Firebird "formula-like" console top to take the new B&M plate. The new plate fit exactly between the bottom of my ashtray button and the top of my window switches.
I also did the wiring of the Radio Shack relay that B&M mentioned; that was easy, too.
Make sure you adjust the cable properly underneath the car!! It's not hard, but a lot of guys do it wrong because it's a pain in the butt. You have to hop into the car, move the shifter, hop out of the car, go under the car, check/make an adjustment, then get up, hop into the car, etc... Do it at least 2000 times! Just joking, but do it more than twice... make dead sure of that adjustment. Use the correct holes in the shift lever, too.... B&M's instructions cover it all.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 15, 2011 | 10:11 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Guys with A B&M MegaShifter
I know this is an oldass thread and I am necro posting, but I cannot for the life of me, get my stock cable to play nice with my megashifter, I widened the slot on the megashifter's tab to fit the cable and bent it, which I believe is how most people do it, but no matter what I do, my cable does not like the angle and doesn't want to face the pin quite the right way either, I have managed to get it on there, and it shifts through p, r, n and drive, but its not smooth at all, and won't reach first gear, need to some advice/tips on how others have done it, pictures would also be great.
Old Jun 15, 2011 | 10:20 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
It wasnt as easy as I thought. The holes are not elongated for the microswitches. I recomend doing that yourself before you get it set in there. also to give yourself more room id recomend removing the center console.
camaro11j
Sep 19, 2018 08:49 AM
neekolzun
Aug 24, 2015 04:59 PM
crazynights
Aug 21, 2015 06:53 AM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
