T 56 4th gen clutch cylinder not fitting on 3rd gen pedal.
Old Jul 31, 2001 | 08:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I put a t56 in my 91z28 and now I cant get the slave/clutch cylinder rod to go on the clutch pedal. the end of the rod has a plastic bushing of some sort and it doent fit at all. How did you guys get your on.
Old Jul 31, 2001 | 08:37 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
i took it off (the bushing) and used a c-clip to hold the rod from falling off the pedal nipple
1987 GTA 355, carbureted, TFS heads(non G2), 6-speed, McLeod clutch, 11.3:1, dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 z-28 wheels, soon to be replacing weak 10 bolt with 12-bolt...gettin tired of breakin axles....
...Whatever turns your tires.....
Old Jul 31, 2001 | 08:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
thanks. that was what i was gonna go next. the end of the piece of the pedal has a groove around it to hold a c clip i think. do you know where i could get one without searching all over the city.
Old Aug 1, 2001 | 07:44 AM
Mark W. Winning's Avatar
I did the same thing, but there was not a bunch of room for the c-clip. After it popped the second time, I removed the pedal, drilled a small hole near the c-clip groove and put it all back together. When it was all installed, I put a pin through the hole to make sure it doesn't come apart again.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Aug 1, 2001 | 11:21 PM
Car: 87 GTA
Engine: 355 Chevy
<font face="Verdana, Arial" size="2">Originally posted by BOTTLEDZr28:
thanks. that was what i was gonna go next. the end of the piece of the pedal has a groove around it to hold a c clip i think. do you know where i could get one without searching all over the city.</font>
Auto zone or an equivalent should sell an assortment. Make sure it fits tightly, or youll have the problem I had with the rod popping off the pedal.
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
