LSD replacement, a few questions
Old Apr 24, 2009 | 05:38 AM
Hasselhof's Avatar
Car: 1988 Trans AM Gta
Engine: 6.0 Liter TPI
Transmission: TH700r4
The LSD in my 88 trans am gta is worn out. Resulting in sad one weel burnout.
Im looking for an easy drop in replacement. I have no experience in the workings of the rear diff, so I will have to pay my way out of this.
The car is only used for funn around the town driving ie. stoplight burnouts and a few donuts, so the most important thing is that when asked to, both weels turn.
I have been reading up on LSD choices and the Powertrax No-slip traction system seems like an ideal choice for my use.
It is described as a direct bolt in replacement. is this true ?
Does it matter what gear ration I have ?
As I understand it the only thing that matters is if one have a 7.5 or 7.625. Is this correct?
Old Apr 24, 2009 | 06:53 AM
big gear head's Avatar
Re: LSD replacement, a few questions
The Power Trax will not work in the differetnial that you have right now. You will first have to swap the differential and then install the Power Trax. If you decide to go with a Power Trax the Lock Right works much better. The No-Slip has caused a lot of problems.
A better choice in your case would be the Eaton Posi. The installation will be just as easy because you are going to have to replace the differential anyway. As long as you have a 3.23 to 3.73 gear the Eaton will be fine. The price is $445 and you will need bearigns and shims to go with it. Here is something to help with the installation. http://www.nastyz28.com/forum/showth...ht=change+posi
Old Apr 24, 2009 | 10:26 AM
Hasselhof's Avatar
Ok, this was good information. From all that I have read It was not clear that the Powertrax could only be put in a differential that was open to begin with, and not one that was originally an LSD.
I have been looking at my RPO codes find out what gearing I have. But I can not find any of the codes for the 10 bolt. Could I have a different differential alltogether ?
(im currently on business, the car is 5000 miles away, so I only have the vin and rpo to look at)
would you mind looking at my RPO codes :
http://www.i-charger.eu/trans-am-rpo-koder.jpg
Maby im blind, but I cant figure out what gears I have.
thank you so much!
Old Apr 24, 2009 | 12:48 PM
I don't know what GW6 is. I have never seen that code before. The GU6 is a 3.42 gear and the G80 is the limited slip differential. Maybe the GW6 is suppose to be a GU6?
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
