gear swap
gear swap
i have( 2.73 STOCK)i now have 3.23 with 26 splines.can i put the 3.23 carrier in my 2.73 axle .while still useing the 2.73 spiders(28 SPLINE )or should i, can i just swap the ring & pinion from 3.23 carrier to 2.73 carrier ?
*1991 Formula WS6 305 TBI
*K&N 14x3" Open air *filtercharger accel-*8.8's,coil,cap,rotor,module.
*poly's TRANS,SWAYS LINKS&BUSHINGS
*245/50R16 255/50ZR16
*3"catco cat
*3" Borla cat back
*3.27 POSI(B&W)REAR DISC
*STRUT TOWER BRACE(EDELBROCK)
*WONDER BAR(GM)
*ADJ PANHARD BAR(HOTCHKIS)
*TRAILING ARMS(HOTCHKIS)
*HYPERTECH THERMO CHIP,160-THERMO,JET FAN SWITCH
*LOT MORE TO COME
*3"catco cat
*3" Borla cat back
*WONDER BAR(GM)
*LOT MORE TO COME
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, you cant put 3.23 gears on a 2.73 carrier.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
ambainb
Apr 25, 2016 09:21 PM
