How do i change the front seal on my rearend????
Old Aug 4, 2001 | 02:41 PM
Artic White Z's Avatar
the seal on the front of the pumpkin is leaking. last time i drove my car the oil leaked out on the drive shaft and threw it all over. how do i go about changing this seal? do i have to take the gears out? Please help! i have never worked on rearends!
Old Aug 4, 2001 | 03:08 PM
ede's Avatar
ede
remove the drive shaft
scribe a mark on the nut and on something for referance, also i'd measure the amount of the pinion shaft sticking out of the nut with a depth mike or dial caliper
remove pinion nut
remove drive shaft yoke
remove seal
install seal and put grease on the rubber part
install yoke
install NEW pinion nut
match up referance marks
install drive shaft
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 5, 2001 | 11:43 AM
82z's Avatar
82z
I would recomend turning the pinion nut a little bit past the refrence mark to crush the crush sleeve a little bit more. Make sure you have a good way to hold the yoke and tighten the nut. They take somewhere around 300lb-ft. Impacting the nut on is not an option.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Aug 6, 2001 | 10:01 AM
This is a realy stupid question but where do i put the oil in the rearend? i thought it was supposed to have a bolt on top of the pumpkin but it doesnt. it just has a hole. in my manual it shows a thing sticking out of "the hole" called a vent but it aint there. i found a thing on the side that you can stick a ratchet in but i wasnt sure if that was the hole to fill it with. where the hell do you fill the rearend at!?
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
