Noise and shake in rear right side..wheel bearing
Old Apr 25, 2009 | 07:50 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Hey Guys,
I took my Trans Am to get a front end alignment and possibly brake job done yesterday.
They told me the brakes were in great shape and said the "shudder" when applying the brakes is coming from the right rear side...and is a wheel bearing going out. I noticed a whine at high speeds too.
I have the rear drum set-up and was wondering if anyone has ever replaced this bearing and can direct me to something with pics?
I have a factory shop manual, just wanted something to give me some direction before I start.
I tried to do a search, but there isn't a thread I could find that "stands out" addressing my issue. I did find this...anyone have anything else?
https://www.thirdgen.org/forums/tran...ing-axles.html
Old Apr 25, 2009 | 08:27 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Noise and shake in rear right side..wheel bearing
Disassemble the rear as posted in the link other than the brakes . You only need to remove your wheel and drum and axle to get to your bearing and seal .
Old Apr 25, 2009 | 08:50 AM
Car: 1971 Camaro
Thanks!
Anyone have a napa, advanced, o'reilly, Autozone, or GM part number handy for the bearing(s) ?
Old Apr 25, 2009 | 09:09 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
No but the parts store should have what you need .
Old Apr 25, 2009 | 09:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As mentioned in the link, inspect the axle itself for wear. You may require a new axle or at the very least an axle saver-type or off-set bearing.
JamesC
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BlackBoulder
Aug 11, 2015 11:15 PM
