th400====does it really fit?
Old Aug 3, 2001 | 08:59 PM
84IROCz28's Avatar
I have a turbo 400 in my 84 z28. I've been told it's a tight fit by some, and others say it shouldn't fit at all. Well, it's in there alright, but the brace that's holding it underneath looks like it's rippin a little, and the linkage is very jimmy-rigged <my pardon's to anyone named Jimmy>
If a tranny the size of mine were to be properly installed, what would need to be done? Mabye it'll be better to take it out and put it in right. The car vibrates slowly but loudly at around 55mph and above, and I think it might be due to the tranny being put in wrong. Any suggestions would help immensly guys. Thanks
Old Aug 4, 2001 | 12:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 400 isn't particularly big or anything. What ever fit problems you are having isn't because of that. If it's a 400 and not a 375, it has a different output shaft than a 700 or T-5 (both of which are the same as a T-350); I'd look at things in that area if you have a post-trans driveline vibe. It would need one of those special U-joints, which is probably bad; unless somebody had a drive shaft made up for it, in which case it might be unbalanced or not true or something. Defintiely get the mounting situation straightened out though; if the drive shaft comes out of the trans for any reason at speed, it will fall out and hit the ground, and pole-vault the rear end through the rear of the car. That's why tracks require drive shaft loops.
ICON Motorsports
Old Aug 5, 2001 | 12:57 AM
84IROCz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
What is a Drive shaft loop? I don't have the money to get that taken care of before I go to colorado (from washington), so maybe a drive shaft loop would be a good investment for me.
Old Aug 9, 2001 | 02:47 PM
82suped-up-coupe's Avatar
the angle that the drive shaft comes out of the tranny has to be within spec or you'll get a vibration and shortened u-joint life
Old Aug 9, 2001 | 07:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Where were these people who said it shouldent or wont fit getting thier informnation from?
The 400 isnt much larger than a 350 the only problems Ive had from 700r4 to tb350 to tb400 is the downshift linkage "the 400 has electronic downshift that attaches to the gas pedel", the crossmember had to be relocated a few inches and the driveshaft had to be custom made from the 200c one and a 400 yoke 200$ So you might want to find a shop that does custon driveshaft work and ballancing.
The driveshaft loop is just a piece of metal "U" that is bolted to the bottem of the car the driveshaft goes through this, If the drive shaft pops out of the trans it will only travel a few inches and not hit the ground saving you from driveshaft and rear end damage.
Good luck!
SSC
Old Aug 9, 2001 | 09:31 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Hurst makes a changeover kit for both the TH350 and TH400. The TH400 kit comes with the new crossmember. Both come with a bracket allowing you to reconnect the torque arm.
http://www.mrgasket.com/ftp/pdf/Accessories.pdf
It's on page 8
Hope that helps.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
