700R4, Kickdown Valve?????
Old Aug 13, 2001 | 09:29 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I had a tranny rebuild about 5k miles ago. Before I didn't have OD, I think because the owner before me installed one of those kickdown valves that allows you to cruise in OD at high speed. Well anyway he wired up some switch I guess to activate it. But when I got my tranny rebuild I figured the guy took it out. But I was thinking the other night that I can cruise in OD at WOT. So I figured he didn't take it out. So I fooled with the switch and when I come to a stop in OD the car acts like it wants to stall for then idles fine. It shifts kind of weird as well, not that that matters I have shift slippage on the 1-2 and the rpm's flare up on the 2-3. I was wondering what this switch does.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 13, 2001 | 03:08 PM
Pro Built Automatics's Avatar
First set your TV cable as transfixleo says in his posts. If you do this and still have 1-2 slide and the 2-3 flare, make sure the Corvette servo was installed, because this should have solved the problem. If not I would talk to the people that built the transmission about this. The switch has to do with the torque converter lockup only.
Hope This Helps!!!
Old Aug 13, 2001 | 08:31 PM
Car: 99 Formula
Axle/Gears: 342
I haven't had the corvette servo installed yet, I got it after the rebuild but I am going to have this guy install the servo soon. Are you sure the switch is for the TC lockup, it was there when I first got my car, and now I believe that the guy who rebuilt my tranny told my Dad that he put in a hydraulic NON lockup TC. By the way I also have the TV cable set the way transfixleo describes.
Back to that switch, if it is indeed for the TC, would it cause a stalling type feel when slowing down while downshifting.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
355tpipickup
Sep 13, 2015 11:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
