Corvette Servo question Please Help.
Old May 2, 2009 | 04:08 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I just had a Corvette servo put into my 89 700R4 tranny today...The trans already had a B&M Shiftkit in it, and shifted pretty good...With the new servo the 1 to 2 shift is weaker than it was, it is much like it was before the shift kit was installed...Any ideas on what could have went wrong???? It came with new o rings, could one have been left out??? Thanks for any help on this subject.....Tom
Old May 18, 2009 | 09:28 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Corvette Servo question Please Help.
Well the problem was incorrect instalation...It now shifts very hard.....There was a small pin that was not installed correctly, or not at all......Tom
Old May 19, 2009 | 10:41 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm glad you got it resolved, and I'm sorry none of us had the answer for you.
Old May 19, 2009 | 10:42 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And by the way, thank you for sharing, in case anyone else ever has that issue.
Old May 19, 2009 | 11:33 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
Super servos are where its at...not much more then a corvette servo from what I remember but mine has been in for 3 years now.
It sounds to me they just didn't get the spacing right. if the pin was not installed at all then you would not have had a 1-2 shift. The servo you had replaced applies the 2nd gear band via fluid pressure and that pin. when you buy a super servo for example they give you a spacer to allow you to get the proper length needed.
Thanks for this post!
Jason
Old May 20, 2009 | 05:56 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks everyone.....I have been helped more times on this board than I can count.........
Old May 20, 2009 | 07:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Jason
i used one of those super servoes in my old 700r4, it was great
Old May 21, 2009 | 10:03 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Mine works real well now...It makes The car so much more fun to drive...It was just an instalation problem im sure....Tom
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
redmaroz
Aug 16, 2015 11:40 PM
