Torque converter lockup switch
Old May 6, 2009 | 10:20 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Hey, does anybody know where the torque converter control wire plugs in at on the tranny? I want to splice into it and add a switch to my center console to lock it up when I need it. Any info would be nice.
Old May 6, 2009 | 10:38 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: Torque converter lockup switch
Hello? Anybody?
Old May 7, 2009 | 02:49 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
be careful. if you do make a manual toggle to pin A to power you should always have a brake interrupt in line with the toggle for emergency situations. you don't need it to be locked with the brakes on anyways. Pin A is drivers front wire on the four pin connector. left front.
Old May 7, 2009 | 10:43 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
where is it located? are you talking about the computer connector or the tranny connector?
Old May 7, 2009 | 03:20 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
