TH-350 help please!?!?
Old Aug 19, 2001 | 06:18 PM
chicksL69's Avatar
I just fired up my freshly machined 327 in my 84 camaro. Everything mechanical is new except for my transmission which does'nt seem to want to shift out of 1st. What could the problem be? I have brakeline running from the vac-modulator and a new vac-modulator. It's hooked into the vaccuum port in the back of my intake. Could it be because of my kickdown cable is not hooked up right? How do you hook it up right? Any other suggestions??? I just wish it would shift outta first!! I also put a shift kit in it. Thank you for the help.
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
Old Aug 19, 2001 | 06:53 PM
chicksL69's Avatar
One more thing, what is the governor that I keep reading about?? Is that the little thing that screws into the tailshaft and turns the plastic like gears in there? on the drivers side? I thought that was the speedometer hook-up. thank you
Old Aug 19, 2001 | 08:10 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep the kick down cable HAS TO BE CORRECT in order to operate properly. To adjust the cable have someone sit inside the car and push the gas pedel to the floor, then check the cable for free play or over tightness to adjust it just push the little black button in and slide the cable back or forward depending on whats wrong. There should be a little slack in the cable a few centemeters is normal.
Good luck!
SSC
Oh BTW the governer is a T shaped kind of thing the two arms - - move inward this governs the shift points. I dobt this is your problem though.
Old Aug 19, 2001 | 08:32 PM
chicksL69's Avatar
ummm. I think you're talking about a 700r4 with "pushing the button" th350's have a kickdown cable, not a tv cable. thanks anywaays though
Old Aug 19, 2001 | 09:19 PM
Jay 727's Avatar
It's not the kick down cable, you can leave it off but it's not recommended. I'd check the governor, my guess would be that the trans is set up for something like a 3.73 gear and you have something in the 2.73 to 3.08 range? Might also check the shift linkage for correct adjustment. I could be the vacuum modulator out of adjustment, aftermarket replacements have a set screw inside the hose connection. Make sure it's connected to a direct manifold vacuum source. The governor is located on the drivers side in front of the speedo cable under a round cover. What is the history of the trans? have you seen it work properly before?
Old Aug 19, 2001 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not shifting out of first is usually a modulator problem.
Take the vacuum line off the modulator. With the engine running put a finger over the line. You should feel suction at idle. If there isn't then either the line is plugged or it's ported wrong.
If you can get it to shift to second at WOT only then the detent cable needs to be adjusted.
Last thing to check would be a defective governor. It's behind the round cover on the drivers side at the rear of the tranny. You can take the cover off and pull the governor out to inspect it.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
TexasMaro
Sep 15, 2015 06:50 PM
Dan83
Jul 19, 2003 03:30 PM
Changa2
Mar 31, 2002 03:09 PM
88 Formula
Mar 15, 2002 07:31 PM
chicksL69
Nov 8, 2000 06:24 AM
