Anyone who knows some stuff about T-56's please read
Old Aug 10, 2001 | 05:18 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Alright heres the deal. I bought a 1997 T-56. All it comes with is the bellhousing. I thought I heard something about there being two different slave cylinders for these trannys.Is this true? If so can do I have to get a 97 slave cylinder? I have a chance to get a 95 will that work? thanks for any help!
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
SLP headers, completely done over suspension, black paint with flames, NEW PLAN IN THE MAKING:
BUILD A WILD CHEVY 302 JUST LIKE THE ORIGINAL Z28 HAD
Old Aug 11, 2001 | 02:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont know about two different slave cylinders, but yes, one from a 95 should work. A new one is about $100.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 11, 2001 | 06:51 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Hey thanks for replying. $100? Does that include any of the hoses?
future mods:
Old Aug 12, 2001 | 12:43 AM
troutkilla's Avatar
Yep it comes as a complete sealed unit, with the master and slave and all the hoses.be careful not to get any air into your unit.I learned the hard way and had to replace one.Ive read that you can bleed these units but it's not that effective...good luck...87 T/A WS6 6 SPEED 373 's
Old Aug 19, 2001 | 10:03 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I need help with the wiring part of the swap. What do I need to make the reverse lights work and the clutch safety?
future mods:
Old Aug 19, 2001 | 07:17 PM
kevinc's Avatar
Car: 1982 Z28
David Arntz posted the part #s for the connectors a while back:
Reverse Lockout Connector: GM#12101857
VSS Connector: GM#12101899
Backup Light Connector: GM#12085485
Wire the VSS to your ECM if you're still using one, otherwise wire it up to an electronic speedometer so you'll know how fast you're going.
The Reverse Lockout just needs voltage and a ground switch, some people have used the brake pedal switch...others just left it out of service and "crash the gate."
The Backup Lights are just extended from your existing shifter harness to the T56 connector.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Aug 20, 2001 | 11:12 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I am swapping from an auto how do I know which wires go from the neutral safety switch to the T-56?
future mods:
Old Aug 20, 2001 | 12:44 PM
kevinc's Avatar
Car: 1982 Z28
Get a Helms manual.
1982 Z-28
Old Aug 21, 2001 | 12:28 AM
89ROC's Avatar
super83Z - take a look at macewen's web page. He has an excellent tech article on the swap. It tells which wires to bypass the neutral safety switch, and the wires for the reverse lights to work. Actually I think his atricle is posted on this site under 'Tech articles' on the front page.
Good luck!
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
cRoe4
Aug 7, 2015 08:46 PM
