T56 and Carb
Old Aug 19, 2001 | 03:55 PM
AdamS91RS's Avatar
T56 and Carb
Im looking into the possibilties of building a 350 carb engine. I also want to swap in a T56. Will there be any problems with running that tranny behind a non computer controlled engine. Ive read the tech article but that was for a TPI Iroc. Any information regarding the swap would be helpfull? I want to know as much as possible.
Adam
Old Aug 19, 2001 | 07:27 PM
83CrossfireBomb's Avatar
from the hours of reading posts and tech articles on this forum, i would say there should not be any problem since the only electrical connections are back-up lights and that switch that allows you to crank the engine only when the clutch is in.
the only problem other than the crossmember that i could see is hooking up the speedo. i think the T-56 has the electronic. if you have an electronic one already your probably a step ahead of the mechanical driven speedo guys. i dont know if the electronic ones are compatible with a T-56 or not either.
but i havent done the swap myself but from what ive read that seems to be the main problems
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 21, 2001 | 11:54 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Sure you can mount a T-56 behind a CARBED engine, my buddy in CAL. who runs in the 185 MPH class in the PONY EXPRESS 100, has this very setup. MECHANICAL ROLLER ZZ-3 block with IRON BOWTIE heads, and a 1996 T-56 with RAM 4-fingered disc clutch. He used the VDO programmable electronic speedo, and TACH. BTW, The VDO speedo DOESN'T NEED A BUFFER, it will calibrate to the T-56.
Also, I used a 1994 T-56 with JTR "MECHANICAL SPEEDO modified tailhousing" in my T-56 conversion 3 years ago. JTR doesn't offer this service anymore, unfortunately. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
topteam54
Oct 6, 2015 12:21 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
