Hurst dual gate in a Firebird, can be done..
Old Aug 21, 2001 | 04:16 PM
92fire-audio's Avatar
For those of you who wanted to know if the hurst dual gate would work in a firebird, the answer is yes. There is some modifications to be done to the console cover (same as with a megashifter) and also, the ash tray has to be cut up to clearance the park lock cable. None of this can be seen though unless you take the top off of the console...
I had a megashifter and just got this today, besides their tech help being nonexistant, it went in ok, easier than the megashifter..
Old Aug 21, 2001 | 08:32 PM
R.O.B.'s Avatar
Please post some pics!
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 21, 2001 | 10:19 PM
I'll post a pic or two in a couple days, check back then..
Old Aug 21, 2001 | 10:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by 92fire-audio:
the ash tray has to be cut up to clearance the park lock cable</font>
The ash tray doesn't fit in the Camaro either.
Old Aug 22, 2001 | 12:57 PM
Well then I suppose the only difference is that the top cover needed to be cut, on a camaro it just bolts in I think..
Terrell351
Jun 13, 2021 01:13 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Dialed_In
Aug 20, 2015 01:45 PM
