How many daily drivers with a POSI here?
I got a POSI to install but don't know if I really want to.
Cept on a take off 1 wheel peel is nice, I sort of don't look forward to going sideways in the rian and stuff when it shifts hard. [built tranny, shift kits, kicks like a mule.] I also drive in snow when its not to deep, its also nice that I can go sort of nuts and the 1 wheel spin doesn't make the rear go all over. I stay straight, just spin.
How big of a learning curve is it to be able to drive pretty much the same but not have the rear end kick out or try to walk around in front all the time???
I sort of like being able to go all out and not lose control with the 1 wheel peel.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: How many daily drivers with a POSI here?
Don't be a wimp. I daily drive mine with posi. Not really too much difference. Just be smart about it...
Car: 1991 Z28
Engine: 5.7 ltr 350TPI
Axle/Gears: 3.08
mine is a posi as well...not much difference at all.just go easy at first until you get use to it
Well if I can't get it running again the point is almost mute, Im ready to shoot the thing as I take real good care of it. tunes ups n oil changes and all more then needed. New parts galore.
https://www.thirdgen.org/forums/tech...-before-i.html
My daily driver has a locker in it. If I can drive every day with a locker then you can easily drive every day with a posi. I've had several posi rear ends and it's no problem to drive them in any weather. The one wheel burnouts that you are doing right now are destroying the differential in your rear end.
I have had a LIMITED SLIP (RPO G80) since I bought the car new and it is nothing out of the ordinary driving with it. I had one with a 10-bolt and now with a 9-bolt and there is nothing different between them. But the 9-bolt one will step out on me if I gas it in a turn, and I think that is the difference between the 305 TPI & 350TPI.
. Senior Member
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
i gotta open diff, and it still steps out on me. id like to have a posi, but like i said even with an open diff it steps out like crazy. just gotta gas it some more and turn right to go left
i miss the dirt track days
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I've had both pegleg and posi in mine,posi was a big
improvement-better traction in snow and on ice
(back when i used car year round),better launches
of course.car will haze both tires going perfectly
straight if car is straight when gas is hammered.
Also posi helps with manuvering in close quarters
as you can just tap the gas to swing the back end
around
around
Car: 1984 Z28
Engine: none
Transmission: none
All I gotta say is that now that I daily drive an s-10 with an open diff I want my z28 with posi again, the added traction was always nice to have in rain and snow.
Andrew Prakash
Sep 8, 2015 11:48 AM
