700R4 to 2004R, needed parts?
Old Aug 22, 2001 | 07:56 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Does anyone know of anybody who sells the crossmember and other related parts to go from a 700 to a 2004R? What about getting the parts from Pontiac or somewhere that were used in the 89 Turbo T/A's? Is it available? I'm sick of having 700R's with their problems. The 200R4 is just a better way to go and it's worth it to me to swap out the 700R instead of wasting anymore money rebuilding another one of these units.
Old Aug 22, 2001 | 10:53 PM
Xenodrgn's Avatar
Sorry, I'm not answering your question, but I do have a quick question about the 200R4... it doesn't have the huge 1-2 gap that the 700's do, does it? What are the disadvantages to using it over the 700?
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Aug 22, 2001 | 11:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Steve Spohn makes a crossmember and torque arm for the 200-4R.
Old Aug 24, 2001 | 06:26 AM
ryn28's Avatar
Engine: Chevy ZZ4
Thanks, I'll check out his parts. I already bought his lca's and lca relocation brackets but didn't see the tranny stuff, guess it was b/c I wasn't looking for that then.
I can think of no disadvantages to running the 2004R over the 700R, only advantages. Your correct that the 200R doesn't have as big a gap between the 1-2 shift. It also can be built alot stronger then the 700R.
If there is a disadvantage it's that you have to spend the extra money on a new drive shaft, crossmember, etc. but that's about it.
Old Aug 24, 2001 | 07:41 PM
Project86Iroc's Avatar
Well, I could tell you a few diasadvantages. I replaced one for a guy with a 700r4 who had rebuilt it twice prior. They dont stand up well behind ANYTHING above stock, at least from my experience. As far as parts to retrofit. Your frame is predrilled for it(it waas at one time the tranny for the thirdgen. SO get a torque arm/crossmember/driveshaft out of an 82 Z28 and you will be fine. Mike. Btw, Im in no way putting you down for converting, I just havent known anyone to like them
"Experience life, Don't use it" Julie (petrick) Fink
Old Aug 24, 2001 | 09:13 PM
ryn28's Avatar
Engine: Chevy ZZ4
I don't know, they are suppossed to be pretty stong, especially when built up. The 700R is known to be weak and even building them up they have some weaknesses that can't be fixed. I don't doubt you know people who's had bad expierences but for me the 700R has been nothing but headaches. I could drive the car fine, don't get me wrong, but I wanted more race performance and this thing doesn't have it.
As far as the torque arm/crossmember from the 82 Camaro, does the torque arm bolt to the crossmember or to the tranny b/c I heard the 200R doesn't have provisions on it for the arm. Also, wasn't the 200 used in those early third gens a 200C three speed? I've heard of a metric 200R and was told that's not what I want either. It has to be the ones from the TTA or Buick G/N.
Old Feb 21, 2011 | 02:58 PM
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
Re: 700R4 to 2004R, needed parts?
the gear ratios on a 200r are MUCH better than the 700r, Art Carr has made a 200r that can withstand 1100 hp!!!!! checkout umi p/n 2217.
Old Mar 24, 2011 | 04:17 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
What all needs to be swapped for the 200? I'm thinking of ddoing this eventualy in my 84, though I just put in a new aluminum drive shaft, will I have to get a new one? Only reason I ask is because Inland Empire advertises it as an 82-92. How about the tranny coolant lines to the radiator?
Old Mar 26, 2011 | 08:54 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I know a guy who builds 700r's for $2795 can handle about 700hp and 3 year warranties. the 200 is a **** trans
Old Mar 27, 2011 | 10:27 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
New driveshaft will need to be 2.92 inches longer.
Crossmember mounting point is further back (it's the same spot as a TH400.) To address this and the torque arm mounting, go aftermarket crossmember w/ tq. arm mounting points.
Coolant lines fit fine.
I've had 5 different stockish 200-4Rs and 700-R4s in my 87 and that's just since I bought it. I prefer the 200-4R.
Old Mar 27, 2011 | 06:35 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
what about the speedometer
Old Mar 27, 2011 | 06:38 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Well, I have a mechanical speedo, and I would assume (bad thing to do in most cases), that as long as you get the right drive/driven gears, the speedo cable will mount up though you may need to lenghthen it depending on it's location on the tranny.
Old Mar 28, 2011 | 12:44 PM
jmd's Avatar
jmd
For a 200-4R into a speed density / elec speedo car, you'd probably want to go with an aftermarket VSS that threads onto the speedo driven gear sleeve. The 1989 Turbo TransAm had a VSS but it would be hard to find, the wrong signal and wrong pulse count.
http://www.transmissioncenter.net/sp...n_______va.htm
#350E (use of buffer box to adjust the signal)
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
# 4PAC (4004 AC pulse per mile as req. by the `730 ECM)
The transmission will still require the correct ratio speedometer gears (1001rpm @ 60mph)
Old Mar 28, 2011 | 11:35 PM
tekkitan's Avatar
Car: 87 IROC-Z
The 200C maybe. The 2004R, as has been said, can be built to handle over 1000hp. So why are you bashing it and saying to get a 700hp capable 700R4?
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
