Can the TV cable be used to lower shift points?
Old Aug 23, 2001 | 07:33 PM
Like a ROC 89's Avatar
I have an 89 Iroc-Z with the L98 and the stock 700R4. When I run at the track the trans usually wants to shift at about 5600 RPMs at WOT with the TV cable adjusted using the GM method. I would like it to shift more around 5000 RPMs at WOT. Now can I just move the adjuster towards the front of the car more so it lowers the shift points to 5000? Will this do any damage to the trans? Will it affect the firmness of the shifts? If this is not correct do I need to change the govener in the trans, if so what part number for 5000 WOT shifts???
Old Aug 23, 2001 | 09:01 PM
breathment's Avatar
shift manualy..
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 24, 2001 | 02:50 PM
Shifting manually does NOT allow you to shift sooner!!! All it does is allow you to hold the gear longer!!!
Old Aug 24, 2001 | 04:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Don't use the GM method for adjusting the TV cable. Look at other posts referring to the cable and follow transfixleo's method. Also readjusting it out of the proper place will damage the tranny because the pressure will be messed up.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 24, 2001 | 08:01 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Isn't transfix's way is the same??
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Old Aug 24, 2001 | 08:21 PM
Jay 727's Avatar
You can adjust the cable to lower the shift points, it will also lower the downshift points while driving. Just be extra sure the trans doesn't slip after the adjustment. The correct thing to do would be to use a governor with heavier inner weights.
Old Aug 24, 2001 | 09:22 PM
Pro Built Automatics's Avatar
Do not use thr TV cable to adjust the WOT shift points, you will destroy the transmission. Do the changes to the governor!
Old Aug 24, 2001 | 11:13 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Like a ROC 89:
Shifting manually does NOT allow you to shift sooner!!! All it does is allow you to hold the gear longer!!!</font>
ya, i was thinking backwards. sorry
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 26, 2001 | 05:52 AM
transfixleo's Avatar
Ditto to what Pro Built said. Messing with the TV Cable will lower max line pressure just when you need it least. The Governor controls your max throttle shift opints. Get the B&M Governor calibration kit.
Old Aug 26, 2001 | 09:30 PM
Cosmik Debris's Avatar
I have an 89 Iroc-Z with the L98 and the stock 700R4. When I run at the track the trans usually wants to shift at about 5600 RPMs at WOT with the TV cable adjusted using the GM method. I would like it to shift more around 5000 RPMs at WOT. Now can I just move the adjuster towards the front of the car more so it lowers the shift points to 5000? Will this do any damage to the trans? Will it affect the firmness of the shifts? If this is not correct do I need to change the govener in the trans, if so what part number for 5000 WOT shifts???</font>
Do NOT alter the tranny shift points by adjusting the TV cable. You will lower the line pressure and risk burning your clutches. The correct way is to buy a governor recalibration kit.
Azrael91966669
25
Jun 20, 2017 04:04 AM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
